Forte fuel system cleaner Anyone recommend it ? / used it - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 12th, 2013, 10:29 AM
Ellies Mini's Avatar
Local Time: 09:02 PM
United Kingdom Female
United-Kingdom Forte fuel system cleaner Anyone recommend it ? / used it
Has anyone used
forte fuel system cleaner and can they recommend it before i buy it.
My local garage suggested it as a good way of cleaning my injectors, and is around £15 - £20 for a 400ml bottle.
I did a quick bit of research but you cant beat a recomendation from someone who's used it and can tell what the results are like.
"Forté Specialist Injector Cleaner will provide the following benefits to all petrol engines:
Reduce exhaust emissions
Remove injector pintle deposits to restore fuel flow
Improve fuel economy and overall engine performance
Neutralise acids and dissolve lacquers from the fuel system
Forté Specialist Injector Cleaner is a complex blend of specially selected cleaning agents which act together to dissolve deposits that are formed in fuel systems which restrict the efficient delivery of fuel to the combustion chambers.
Forté Specialist Injector Cleaner is compatible with all fuel system and engine components, including lambda sensors and catalytic converters.
Forté Specialist Injector Cleaner should be used at regular service intervals or whenever symptoms indicate that treatment is necessary."
Any feedback would be good before i use it.
Thanks peeps!!
Old Feb 12th, 2013, 04:45 PM
Cooper S Jon's Avatar
in the 25yr of driving,covered 450k miles,i've never used any fuel additives in any of the cars i've had,even the one which had 223k mls.
