Hiya, please can you help?! I have a 2002 Mini Cooper. A couple of weeks ago the brake lights came on for no apparent reason whilst the car was parked up. The only way we could get them to go off was to disconnect and reconnect the battery. Since then ALL the electrics keep going and the only way to get them back is to disconnect the negative battery connection and then reconnect it. Everything then appears to be ok and works fine till the next day when all the electrics have gone again and I have to repeat the procedure. I've checked the fuses and they appear to be ok and I think they must be because when it works everything works! Please can you help, I can't afford a hefty garage bill at the moment!
Duff battery probably, if its over 5 years old it needs renewing most likely as that is the main cause of MINI electrical problems you describe as they are very sensitive to voltage drop.
No water leaks? wet carpets?
There are electrical components under the seats and in the boot that if getting wet can cause problems.
Engine earth strap secure?
Alternator giving full charge?
i just replaced a $4000 battery in a customers citation jet 2 months ago and it failed last week!
batteries are mass produced and there will be random early failures
but as other posters have stated, check for water, proper alternator output and good secure wire connections, in particular engine and body grounds
scott
2012 CM S All4 (03/12) | Abs Black w/White Roof/Mirrors/18" White Wheels | Cold Pkg | Sport Pkg | Xenon w/ Black Housings| Manual | Sport Susp| Anth Headliner | Flat Load Floor | Bluetooth | 2 Part Center Rail | Milltek downpipe back exhaust
FOR SALE
2002 (52 reg)Hatchback40,000 milesManual1.6LPetrol
VERY LOW MILAGE. FSH. 3 Door Hatchback, Yellow with black roof, Petrol, 1.6, Manual, Body coloured bumpers, PAS, Passenger airbag, Immobiliser, Side airbags, central locking, electric windows and mirrors, MOT Jun 13. Immaculate condition, must be seen. Only selling as expecting twins and hence require a bigger car!!!. £3,500
