| MINI2 Newbie Join Date: Dec 2002 Location: Nr Cambridge, UK Local Time: 03:51 AM
Offline | MCS. Super Unleaded? What petrol do y'all use in your MCS's??. Mine's two days old and I want to wean it properly! My dealer recommended Shell optimax but I'd like to hear your opinions. Cheers Phillip MSCS, Black on Black, Cordoba, Chilli, MFSW, Visibilty, Chrono, Chrome In and Out, Chrome Caps. Woof! |
| MINI2 Senior Join Date: Oct 2002 Location: Irvine, CA Local Time: 08:51 PM
Offline | Re: MCS. Super Unleaded? I recommend you do a search of the discussion groups. There was a thread on UK petrol brands a month or so ago. I am pretty sure it was not under Interior and ICE though. MINI specifies 91 octane, and there was a clear consensus to avoid cut rate and supermarket gas as it is inconsistent. MC/VR/B/PP&SP/CVT/Xenon |
Offline | The octane rating deals with the amount of anti-knock compounds in the gasoline. If you use a gasoline with insufficient anti-knock compounds, you will over time damage your engine and you will hear "pinging" as you drive, particularly during acceleration and up hills. This does not mean everyone should use Super, it means you should use the grade recommended by the manufacturer. of course, for the MINI, that IS Super. ![]() As I stated above, there are other threads on this subject, and if you read them you will see some of the problems others are having because they are not using the right gasoline. MC/VR/B/PP&SP/CVT/Xenon |
| | #6 (permalink) |
| Sponsor/Moderator/Other Join Date: Jul 2002 Location: Cleveland Local Time: 10:51 PM
Offline | Essentially correct, however the MINI (both of them) have anti-knock sensors, so you'll actually cause your engine to run weaker (lower compression) automatically before you damage it because of too low octane. (In theory at least). With regards to the original post: Calculate the cost of super vs. regular, its at most $.20/gallon. Say you drive ~10K miles/year, which is 250/week, or about 10 gallons (assuming good milage) That's an extra $2/week on gas, or $110 a year. You just bought a car that cost over $20k. The least you could do for the poor thing is give it the gas it needs. Saving money buy decreasing the performance of your car and potentially damaging it would make sense if it was thousands of dollars. Its not. Magic 8-ball was correct. All be in awe of Magic 8 ball. |
| | #7 (permalink) |
Offline | Hmmm . . . I see the thread has been moved to a more appropriate foum. Thanks!Nice to know about the sensors Stryder, thank you. I believe Teddyx is in the UK, and petrol is quite a bit higher there, but overall I agree, a few quid more on petrol is worth it to take care of your new car and enjoy its full potential. MC/VR/B/PP&SP/CVT/Xenon |
| | #8 (permalink) |
| MINI2 Master Join Date: Sep 2002 Location: Mississauga, Ont, Ca Local Time: 11:51 PM
Offline | Re: Re: MCS. Super Unleaded? I realize I am a bit late on this thread but I thinkit is worth noting that 91 octane is the minimum for an S. According to the M-Z artcile is is optimized to run on 98 RON. I don't think you can buy this in N.A. except at a track. Sunoco 94 is the best you can get in Canada - I'vwe been running it since July and feel it is worth the very slight premium over 91/92 octane at other stations aka KWKSLVR Member: Southern Ontario MINI Club BMW Club of Canada - Trillium Chapter |
| | #9 (permalink) |
| MINI2 Regular Join Date: Sep 2001 Location: The Alps (Central Sw Local Time: 04:51 AM
Offline | You are correct, all (three) MINIs have "knock sensors". Using lower octane fuel does not reduce compression but adjusts the ignition timing which reduces power output thereby preventing knocking. Conversely, using the higher octane means getting more power output. I can't get enough of it, so I'm using Shell SUL 98 (Optimax is not sold here sadly). The compression ratio cannot be altered without physical modifications i.e. changing the stroke or bore of the cylinders. Cooper S BRG/B, Chili, DSC, Overheated seats, auto A/C, OBC, heated mirrors/jets, Boost + CD. delivered 24.09.02 (ordered 11.09.01). MAX tint on back 3 windows. 17" S-Lites with Dunlop summer run-flats. 16" X-Lites with Goodyear Ultra Grip run-flats for winter. Remus exhaust (LOUD !). |
| | #10 (permalink) |
| MINI defector Join Date: Mar 2002 Location: Harefield Local Time: 04:51 AM
Offline | Shell Optimax It's a performance car which needs high octaine fuel and Optimax is the cheapest and highest Octaine (nearly 99 ron) ![]() MINI, RX8 and MX5 - Done those............. It's now TTime ![]() ![]() Unofficial MINI2.com bean counter |
| | #11 (permalink) |
Offline | We're making progress on this all the time. (mostly by pointing out flaws from other people) I completely forgot that the MINI doesn't have variable valve timing when I wrote that, which would also allow for performance changes as well. Somehow I had compression on the brain. Thanks for bringing that up. I should also mention we're having gas octane issues based on the difference between RON and MON, US gas (Canada too if I recall) is rated as the average of the two, other places tend to not do that which can make their octane seem higher. As far as I know its nearly (or economically/legally) impossible to make unleaded gas higher then 94 or so (R+M)/2 since certain stations (Southern California mostly) sell 'low lead' which is like 98 or 100, and leaded which is 108 or so. They label it for off road use only, so they avoid any legal problems with still selling leaded gas. (Link about RON + MON here: http://www.refiningonline.com/Engelh...ep/TCR4_29.htm ) Magic 8-ball was correct. All be in awe of Magic 8 ball. |
| | #12 (permalink) |
Offline | Stryder, don't take it personally! We ALL learn something from this site so we should all try to keep it as correct as possible. Oh and VVT has no influence on the compression ratio. It just does what it says: it varies the timing of the opening and closing of the valves. The compression ratio is measured when all valves are fully closed. ![]() Cooper S BRG/B, Chili, DSC, Overheated seats, auto A/C, OBC, heated mirrors/jets, Boost + CD. delivered 24.09.02 (ordered 11.09.01). MAX tint on back 3 windows. 17" S-Lites with Dunlop summer run-flats. 16" X-Lites with Goodyear Ultra Grip run-flats for winter. Remus exhaust (LOUD !). |
| | #13 (permalink) |
Offline | Trust me, I won't. I wasn't being sarcastic, I actually found it sorta funny how its progressing. And I thought more about the post, so as you can see, I actually edited it 5 min after I posted the reply and changed it to not say vvt had anything to do with compression. Its 5am here and I haven't gone to sleep because I'm not tired, I think my brain's stopped functioning in any case so I'll try to sleep now. Magic 8-ball was correct. All be in awe of Magic 8 ball. |
| | #14 (permalink) |
| MINI2 Regular Join Date: Sep 2002 Location: Los Angeles, CA, USA Local Time: 08:51 PM
Offline | 100+ Octane station half a mile from me There is a high octane gas staion right down the road from me here in Santa Monica, CA. It has around 98, 103, 106 Octane... but prices run from $3 - $6 a gallon. I highly doubt putting in any of those octanes would show any performance boost over 92-93 in the S, unless it had 11+ compression ratio. |
| | #15 (permalink) |
| Blindin' Join Date: Nov 2002 Location: The Town Which Fun F Local Time: 04:51 AM
Offline | I run my One only on super unleaded which has an octane rating of 98. This is the maximum octane rating you can buy in the UK (at least I've never seen anything higher). The standard unleaded is rated at 95. I've noticed that it runs much smoother on superunleaded, it may be a little faster too, but I'm not too sure on this - could just be my imagination. Haven't really noticed that fuel consumption is any different. The superunleaded does help to keep the cylinders cleaner apparantly. In the UK there is a 5p/ litre price difference between the two types of petrol. In my area regular unleaded is 74.9p/l, super is 79.9p/l. Convert that to $/gallon and you realise that you americans are on to a good deal! IB ONE, Seven Hole Alloys, Air Con, CD, Chrome bits - Now with Chrome mirrors and chrome side vents + Custom engraved Whalen Shift Knob and four, yes four driving lights! |
| | #16 (permalink) |
Offline | I agree, I have zilch to complain about when I can fill up on 93 (M+R/2) for like $1.40/gallon. I haven't even bothered filling up with anything else, since for $.20/gallon its not worth being mean to the car. Magic 8-ball was correct. All be in awe of Magic 8 ball. |
| | #18 (permalink) |
| MINI2 Newbie Join Date: Nov 2002 Location: Edinburgh Local Time: 03:51 AM
Offline | Optimax is a Shell product. Basically their Super Unleaded option but developed to the next level. Reduces build up of deposits on the backs of valves and inside fuel injectors. I plan to use it where possible when I get my MCS. Cooper S EB/BLK, Chilli pack heated mirrors /washer jets *****ordered 10/11/02***** Collected 4/01/03 --running in-- |
| Unleaded V Super Unleaded/Ultimax/Optimax | Cooper86 | General Discussion | 14 | Oct 3rd, 2006 05:19 PM |
| Any one tried Sainsburys Super Unleaded? | l1dve | General Discussion | 51 | Jan 15th, 2006 10:33 PM |
| 81.8p for Super Unleaded | bc_seventy_six | General Discussion | 2 | Dec 17th, 2004 08:30 PM |
| Unleaded or Super-unleaded | Billy Smart | MINI Cooper S | 15 | Jul 8th, 2004 12:22 AM |
| regular unleaded vs super unleaded | sugster | MINI One | 26 | Dec 18th, 2002 04:33 PM |
