New mini whurring noise from front right wheel - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 5 (permalink) Old Jan 4th, 2014, 10:49 PM Thread Starter
Local Time: 01:55 AM
England
DIY New mini whurring noise from front right wheel
Hi all,
just got my new mini cooper s 04 this morning, very happy with it, however, whilst on the motorway to show it off to friends and family, I noticed a whurring noise which almost sounds like when you run onto the white line at the edge of the road.
It only occurs over around 50 mph, comes from the drivers side front wheel, and appears to disappear when I turn left?
I had a google, and the consensus I have come to is perhaps a wheel bearing problem, or a wheel balancing issue, any ideas?
Thanks in advance!
mk1990 is offline
post #2 of 5 (permalink) Old Jan 5th, 2014, 12:20 AM
Hi ya
I would agree with your wheel bearing idea but not the wheel balancing if the front wheels were out of balance you steering wheel would shake around 60-70 mph ish of the rear would shake.
If you have run flat tire that are unevenly worn or miss matched they sometime cause problems, or even a mix of run flats and normal tires which is not recommended.
I would get you tires and wheel bolts checked and also get the car up on a ramp or similar and get the bearings checked out.
Check your tire pressures are correct as well, but to be total honest if your not happy take it back get the garage to check it out.
What wheels and tires do you have?
Hope this helps
marque is offline
post #3 of 5 (permalink) Old Jan 5th, 2014, 09:47 AM
mab01uk's Avatar
Quoted: 1 Post(s)
I would agree with Marque most likely a noisy wheel bearing in need of replacement......in fact I have just noticed one of my wheel bearings has become noisy! (2002 MINI on 60,000 miles).
mab01uk is offline
post #4 of 5 (permalink) Old Jan 5th, 2014, 09:02 PM Thread Starter
England
Cheers guys,
I rang the garage and let them know and they have agreed to take it back and get the problem fixed, so hopefully won't cost anything which is good.
He agreed as well in thinking it was a wheel bearing issue, but we shall see!
They are 16 inch standard alloys, not sure what tyres exactly, but they aren't run flats as they were recently replaced, which made me think about the wheel balancing issue
mk1990 is offline
post #5 of 5 (permalink) Old Jan 15th, 2014, 07:20 PM Thread Starter
England
Just to update I've got the car back now and it was e passenger side wheel bearing.
All replaced and much quieter now, thanks guys!
mk1990 is offline
2006 1.4 Mini One D Idle Knocking Noise Just purchased. quemlar007 First Generation MINI One D 1 Sep 30th, 2014 02:46 PM
Mini HQ - Terrible ethics for the customer. jobforacowgirl Dealership Feedback 11 May 22nd, 2014 06:36 AM
Brands Hatch Mini Festival 22/23 June 2013 mab01uk Mini Events 20 Jun 23rd, 2013 11:03 PM
Brooklands Mini Day Sunday, March 24, 2013 mab01uk Mini Events 11 Apr 5th, 2013 07:11 PM
Mini Australia service chilld Dealership Feedback 4 Sep 4th, 2012 06:29 AM
