Mini Cooper Oil and Filter Service with EGR Blank - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 6 (permalink) Old Jan 24th, 2014, 06:10 PM Thread Starter
Mini Cooper D R56
Local Time: 10:24 PM
Hi
I have just serviced my Mini Cooper D R56 57 plate.
Just acquired from a garage in Scotland and never sure if their 'oil service' is done, and if so correctly. After dropping the oil, no idea but there is a new air filter...however,
I thought it might be useful to attach photos for those that don't or haven't done this yet.
As you can see. The first thing is a new turbo seal required. Around 12 I've heard so will get that ordered. (Citroen Part)
The parts I bought from my local motor parts. All Mahle equipment which is good enough for me. As it happens, I've kept the air filter as there is a new one in it seems.
Fuel filter in place. You have to remove the air box to get to this. All just pulls out. As it happens there are some broken plastic pins as expected and need replacing. The filter has a clip on the lhs which just presses to lift out. There is an electrical socket which lifts off and fuel pipes which unclip also. All in all, 30 seconds. It's heavy from the fuel still in place.
Again just inclips and then slides back. This is the heater I believe and transfers across to the new filter. Again push fit.
andreweaves is offline
post #2 of 6 (permalink) Old Jan 24th, 2014, 06:16 PM Thread Starter
Mini Cooper D R56
Continued...
So these are the pipes removed from the filter...
Now for the EGR. I want to put a blank plate in this as well as a DPF delete over the weekend. Once done, I'll have it remapped with these taken out.
This last picture is the fuel filter plate which removed gives you better access to the EGR setup.
post #3 of 6 (permalink) Old Jan 24th, 2014, 06:27 PM Thread Starter
Mini Cooper D R56
Continued...
So where was I? Does this 5 picture limit change ever??
EGR valve location with the plate removed.
One dirty EGR valve....
In fairness this was cleaned with a quick hoover...no fluids used and it's clean yes? So question is, what is it like in the inlet? I don't know, it's being blocked either way. Given how delicate the HDI engine is with oil contamination, I'm definitely not risking it. The one thing that the EGR system is good for is heating your engine up quicker, but not point having a broken hot engine
So here is the plate I bought off eBay for 4. Steel option, not alu and nicely finished. Very smooth.
Going here....
tbc....
post #4 of 6 (permalink) Old Jan 24th, 2014, 06:34 PM Thread Starter
Mini Cooper D R56
Continued...
So here is the plate in place.
Now here is the oil filter in a stupid place tbh. Little restrictive but not impossible. 27mm from memory. The filter just pulls out of the cap once free. It can be a little stiff but it comes off.
Lastly just a picture of the turbo inner. Some black on the blades, but looks clean enough.
Anyhow, the pollen filter to be fitted in the passenger cabin, which I'll do later and DPF delete I'll show probably over the weekend.
To note, the panel under the engine, there are I think 8 philips screws. It's a nice easy panel to remove.
The oil, around 3.7 litre was local purchase c3 low ash fully synthetic 5w30 oil.
So the EGR plate.
Yes the light has come on and yes the power is reduced, but I don't think that is limp home mode as it's quick enough at the moment. As said, once I do the DPF delete (because the light does come on sometimes when starting, and then goes) then I'll go for a remap to disable both.
To note the DPF will be gutted and replaced again as it's now an MOT failure to remove completely the DPF.
post #5 of 6 (permalink) Old Aug 30th, 2015, 01:43 PM
Sorry to resurrect an old post but how did you get on with the EGR, DPF delete and remap? In a similar place at the moment and want to know if its worth it.
MrDepths is offline
post #6 of 6 (permalink) Old Aug 20th, 2016, 12:14 PM
Satriani7007's Avatar
Quoted: 2 Post(s)
Hi,i also thinking to blank EGR on my 1.6d PSA,but thought blanked egr should increase or give you back power like was when car was new and not decrase?also wanna know if blanked egr will make smoke from exhaust?
Btw I don't wanna touch dpf
Satriani7007 is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
2003 Mini Cooper service Black9 Maintenance & MINI Care 1 Aug 4th, 2013 11:38 AM
Low Oil Pressure - Filter Debris in Oil System??!! MissMac General Discussion 5 Apr 1st, 2013 10:23 AM
help with how to change oil and filter mini one d romiloned First Generation MINI One D 2 Nov 9th, 2012 11:47 PM
Mini R50 oil filter types Tr0nic Maintenance & MINI Care 1 Oct 18th, 2012 04:27 PM
Service Schedules adham General Discussion 1 Oct 1st, 2012 05:46 PM
