Timing chain procedure question - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 4 (permalink) Old Jan 27th, 2014, 01:02 AM Thread Starter
Local Time: 02:59 PM
Working on a 2009 S.. TC is loose. I have lock kit and tensioner. Crank is locked. CAM "EX" and "IN" is up. Exhaust cam will lock but the intake is too far off to fit the lock tool.
Can the intake be moved with a wrench? Do I loosen the cam sprocket bolts and move the cam to lock?
Does the vanos intake sprocket need some special pre-tension?
Charlie
Referencedesign is offline
post #2 of 4 (permalink) Old Jan 27th, 2014, 01:47 PM
Local Time: 08:59 PM
Cyprus Male
I think that if you loosen the tensioner, you will be able to rotate the cam to lock properly. Yes you can use a wrench to do it, there are grooves somewhere on the camshaft to do so. There was a video from Peugeot showing the exact procedure, I will try to find it...
alexcannas is offline
post #3 of 4 (permalink) Old Jan 27th, 2014, 02:21 PM
Cyprus Male
The video I was talking about... He uses a wrench to bring the camshafts in place. I think, loosening the chain by removing the upper rail and loosening the tensioner will reduce stress on the components. But don't remove the tensioner completely only loosen enough to allow you to place the tool in place.
post #4 of 4 (permalink) Old Feb 3rd, 2014, 05:39 PM Thread Starter
Thank you for the video. My situation is that the exhaust has been locked (Crank locked with tool) but the intake needs to rotate counterclockwise to apply the lock tool. This will not happen because the chain is tight between the exhaust and intake sprockets.
I can remove the Vanos intake sprocket and then move the intake cam counterclockwise to lock position but I'm not sure if that throws off the vanos timing. Is the intake sprocket keyed to the cam?
Mini Cooper S R56 Timing Chain Tensioner Mini Cooper S BUSTED Second Generation Faults & Fixes 23 Sep 4th, 2015 05:24 PM
MCS Timing Chain Tensioner A18XVM First Generation Faults & Fixes 12 Jul 8th, 2015 07:39 PM
2007 Cooper S "Timing Chain Tensioner Defect" igooba General Discussion 1 Feb 14th, 2014 10:40 AM
HELP!!!!! Timing chain JCW replacement (abraxas warranty) RJP1990 Second Generation Faults & Fixes 1 Dec 13th, 2013 04:51 PM
Timing Chain conundrum... MikeJS First Generation MINI Cooper 7 Aug 26th, 2013 11:30 AM
