Hi All, wonder if you can help. We have an 08 R56 Mini One 1.4, this has recently started to make a strange noise when braking.
The noise is from the Rear.
The best way I can describe the noise is its as if you are driving over rumble strips, this only happens when braking from around 20mph and gives a physical feel as though you are actually going over bumps aswell as the noise.
First thought was an egg in the tyre, but it doesn't make the noise/feel all the time only under braking, then I thought Brake Pads, it does grind a little but not all the time, are the wear indicators designed to make this feel/noise.
Hi AMAUTOS7, thanks for your reply, funny you should mention lugs, the same thing went through my mind today, haven't bought pads yet but will be purchasing Bosch parts.
Wife is home now so shall go out and check wheel bolts.
Wheel bolts are all tight, must be pads, just an unusual noise that i've never heard before in 30yrs of looking after cars, as I say just like you've gone over a rumble strip, thud.... thud.... thud with the revolution of the wheels.
I have a slight knocking noise that only seems to occur at sub 20mph speeds and sometimes when under braking too.
After spending a while underneath with a torch, I think its the rear anti roll bar bushes. At first look, the ones fitted at the moment look ok. However after buying some new ones from the main dealer for £8 a pair, if you compare the old and new ones, the old are definitely well worn and even the smallest amount of wear can cause a fair bit of play. I'm hoping that resolves my issue. May be a similar issue for you?
Is there any chance the discs are a little warped? (how many miles ya got) I agree with another reply you got, make sure the pads are Mini pads or up to Mini specs/requirements & stats. The great pad and disc quality are one of the reasons why a Mini can brake so good and offer such great feed back to the driver via the pedal! Hope ya get it figured out... :nice:
Noises are hard or not.I would expect a brake issue to squeak not really noise or may be break pads are lose that's why the noise is emitted or may be its emitted in the tire..
It almost sounds like the ABS is trying to kick in.
Can you confirm if you have had any lights on the dash?
I would check for the wheel sensors, as sometimes they could go out, causing wierd grinding sounds.
Kush
let us know how you get on
Related Threads
MINI Cooper Forum
3.6M posts
159.9K members
Since 2001
