Engine management warning light. - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 3 (permalink) Old Feb 2nd, 2014, 02:56 PM Thread Starter
Local Time: 06:56 PM
Hi,
Would like some advice if possible........
Ok this is the situ,
Coolant temperature sensor failed, and the rad fan kept on cutting in.
To start with no warning symbols came on.
Replaced the sensor, and the fan is now operating normally.
But.....the day before I changed the sensor the EML lit up.
I thought it was due to the sensor but now fixed it cant be.
Tried in vain to do a reset via the stalk and auxiliary controls but cant.
I have disconnected the battery for around ten minutes (as read on the net) to do a hard reset then if it was the sensor it would not light up?
Done this but the EML is still lit, can anyone advise the next move as I dont want to go to BMW.
Car running fine.
Cheers,
Andy.
andrew007007 is offline
post #2 of 3 (permalink) Old Feb 2nd, 2014, 05:43 PM
mab01uk's Avatar
Quoted: 1 Post(s)
What year is your Mini?
The EML light often comes on with raised exhaust emissions, very often it is just an Oxygen/Lambda sensor failing or out of range as they age.......any garage that does MOT's should be able to test your emissions and indicate what is at fault or read the fault code.
mab01uk is offline
post #3 of 3 (permalink) Old Feb 3rd, 2014, 12:42 PM Thread Starter
It is a 2008 model petrol clubman cooper.
Cheers.
engine management light simonjai85 Maintenance & MINI Care 13 Dec 15th, 2015 08:06 AM
Battery warning light, overheating warning light LizzyG Second Generation Faults & Fixes 2 Jan 2nd, 2014 05:30 PM
Oil light and engine management light k12yla Second Generation Faults & Fixes 1 Mar 7th, 2013 06:52 PM
Stalling and engine management light Kwilksy Second Generation Faults & Fixes 2 Dec 4th, 2012 02:21 PM
1st Generation One engine warning light mrlines First Generation Faults & Fixes 4 Nov 17th, 2012 08:42 PM
