Transmission Noise... - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 4 (permalink) Old Feb 14th, 2014, 10:54 PM Thread Starter
Local Time: 08:47 PM
United States Male
DIY Transmission Noise...
So my R53 2005 Cooper S (6 speed manual) makes an interesting noise when I accelerate and let go of the acceleration pedal while in gear... kind of like a tin can rattling against something.
The odometer reads almost 84k miles, and I have no idea if the clutch has ever been replaced (probably not). Is the noise I'm hearing from the throwout bearing on its last legs or is it a sign of a deeper issue with the transmission?
In addition to those questions...
I would like to replace the clutch myself due to the INSANE price quote I got from the closest MINI dealer ($1700 USD! 2/10 of what I paid for the car). I've done it before (in a Toyota however), and being unfamiliar with BMW, what tools are required for that job?
Thanks!
--Ethan
bananalyze is offline
post #2 of 4 (permalink) Old Feb 15th, 2014, 05:46 PM
mab01uk's Avatar
Quoted: 2 Post(s)
The R53 Dual-Mass flywheels have been known to make a rattling noise when worn, so I would replace it along with the throw out/release bearing and the crankshaft rear main oil seal while the gearbox is out for the clutch replacement.
In the UK an R53 Clutch Replacement is around 550 fitted:
Clutch Kit Supplied & Fitted - R53. MINI - Servicing - Repairs - Tuning - Parts - Spares
Here is a useful DIY guide for R53 Mini Clutch replacement:
Pelican Technical Article: MINI Cooper - Clutch Replacement
mab01uk is offline
post #3 of 4 (permalink) Old Feb 16th, 2014, 04:48 AM Thread Starter
United States Male
Good to know. I had never heard a noise like that from a manual trans before. I'll be ordering a clutch kit soon from Pelican, I ordered some things there before and I loved it, but I hadn't seen that tech article. Thanks!
Any idea about how long the current flywheel would last? Is there some sort of imminent failure that comes after this noise? I'm not asking because I want to run it into the ground before replacing (that's just not smart), I just won't be able to get around to it for a few weeks.
post #4 of 4 (permalink) Old Feb 16th, 2014, 09:07 AM
mab01uk's Avatar
Quoted: 2 Post(s)
The DMF flywheels can make an annoying rattling noise (usually heard at idle) for some time before replacement is essential, dual mass flywheels are basically 2 seperate flywheels linked together with springs and rubber to damp out vibrations in the drive train. However it is best not to ignore for too long.....also try to get confirmation the sound is due to the DMF before strip down as these flywheels are quite expensive to replace. Some owners have fitted aftermarket 'solid' flywheels but these can sometimes cause harshness, clutch judder and other problems.
The Mini DMF explained:
murmini - MINI Cooper Blog : The Dual Mass Flywheel
mab01uk is offline
Low Transmission Oil From Factory scarewed Second Generation Faults & Fixes 0 Jan 14th, 2014 12:32 AM
Wits End with this Noise - Please Help! Vicki29 Second Generation Faults & Fixes 12 Dec 29th, 2013 10:35 AM
2005 Cooper S Squealing Noise Independent of Engine Speed uilleann-piper First Generation MINI Cooper S 1 Sep 24th, 2013 09:18 PM
Transmission noise Jay71 Maintenance & MINI Care 2 Apr 25th, 2013 07:26 PM
Noise, Noise, Noise Teddy Boy General Discussion 19 Nov 7th, 2012 01:02 PM
