The best oil to use??? In r 56 cooper s - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 9 (permalink) Old Feb 15th, 2014, 10:51 AM Thread Starter
Local Time: 07:34 AM
I now use castrol edge 00-40 new stuff. Is this the best oil?
Joeyr56 is offline
post #2 of 9 (permalink) Old Feb 16th, 2014, 11:47 AM
...opinionated!
Deep_27a's Avatar
United Kingdom Male View Deep_27a's  &  2nd Gen  Profile View Deep_27a's Classified Ads
I use Castrol Edge 0W-30 for my JCW but used this in my S also.
Not sure if it is the best oil but this is what my main dealer uses and recommends.
Deep_27a is offline
post #3 of 9 (permalink) Old Feb 16th, 2014, 05:53 PM Thread Starter
thanks for the info. does yours burn any oil?
Joeyr56 is offline
post #4 of 9 (permalink) Old Feb 16th, 2014, 05:56 PM
...opinionated!
Deep_27a's Avatar
I burn oil rapidly! I think more than it should to be honest!
Probably about a litre every 2-3K.
Deep_27a is offline
post #5 of 9 (permalink) Old Feb 16th, 2014, 06:01 PM Thread Starter
mines about the same mate. it is normal i belive? just had it remapped aswell the little thing gets so hot its unreal!! the bonnet you cant even touch in places when ive been giving it some stick!
Joeyr56 is offline
post #6 of 9 (permalink) Old Feb 27th, 2014, 04:31 PM
SGT Slaughter & Farm Girl
Local Time: 02:34 AM
United States Male
Just make sure you use Synthetic oil that meets the BMW LL-01 specs, not all do. An oil change vs no oil change is good but You will get better MPG, More Power and a Smoother Running Happy motor with the correct spec Mini oil!
Mini_drive is offline
post #7 of 9 (permalink) Old May 20th, 2014, 07:09 AM
Banned
Local Time: 06:34 AM
I am a mechanic by profession and i used the Red line oil in my Mini Cooper.It works better in my car and i also used it in other cars.Oils are all a like but it depends only on the mileage of car.So you can also use it in your Mini.But i advise you to change your oil for every 3000 miles so it give you a comfortable drive.
habi222 is offline
post #8 of 9 (permalink) Old Jun 28th, 2014, 06:45 AM
Quoted: 1 Post(s)
Recent trip to dealer with my 06 S, beckoned by that yellow SES timer resulted in a 2nd Oxy sensor (1st faulty) under warr, but also yielded a page of "recommendeds" totalling $3700, 2 of which were oil leaks - oilpan & crank position sensor O ring - which I opted to do. However, on way home saw that "oil life" hadn't been reset with 12K remaining, which got me thinking: if it was clean/new looking was I sure they'd installed new, and could this be why no reset of life? I also use "Restore" in my vehicles, as old habit, so was that gone? Since there was no oil item on invoice called next day & was told new oil was 5 w 30 "Mini oil," so I wonder if anyone here knows who makes this or anything else about it, as underhood recommendation is Castrol. Is this a cost saving "house oil?" Dealer's not close or I'd go ask...
zzinglish is offline
post #9 of 9 (permalink) Old Jul 2nd, 2014, 08:04 AM
I use Castrol Edge 5W-40
mrfyzv is offline
Oil question, 52 plate mini cooper S, help a newbie! Lisaa-wilson General Discussion 11 Nov 30th, 2013 12:34 AM
Low Oil Pressure - Filter Debris in Oil System??!! MissMac General Discussion 5 Apr 1st, 2013 11:23 AM
Mini Cooper S, slight oil leak, helped needed! Lainchers First Generation Faults & Fixes 6 Feb 23rd, 2013 11:24 PM
Mini cooper s r53 37,000 using oil is this normal leedslad Maintenance & MINI Care 11 Feb 4th, 2013 11:26 PM
Oil consumption Mini Cooper s N18 engine peterhellawell Maintenance & MINI Care 1 Jan 24th, 2013 10:11 PM
