Changing Oil???? - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 11 (permalink) Old Mar 3rd, 2014, 12:32 PM Thread Starter
SGT Slaughter & Farm Girl
Local Time: 09:55 AM
United States Male
White Cooper Changing Oil????
I read somewhere in here (don't remember where) that Mini has changed their 1st Oil Change/Service to 10'000 mi instead of 15'000 is that true for all Mini's or?????????? The wife and I have a 2014 Countryman S All-4 coming from the UK in about 2 months or so. So is what im asking is should I still consider changing oil myself after 3-5000 mi? Or wait till the Car says to???
Mini_drive is offline
post #2 of 11 (permalink) Old Mar 3rd, 2014, 09:15 PM
Local Time: 01:55 PM
Quoted: 2 Post(s)
United Kingdom View AMAUTOS7's Classified Ads
Change the oil every 10,000 miles
It does the engine and turbo a world of good
AMAUTOS7 is offline
post #3 of 11 (permalink) Old Mar 3rd, 2014, 10:29 PM
Hi ya
As above clean oil is good oil :-) also buy your self a "dimple" to (magnetic sump plug)
If you keep the oil clean you will minimise the carbon in the oil system which will reduce wear, clogging of oil galleys, damage to lifters and tensioners then the down ward spiral starts.
I do my MCS half the recommended I think I do mine every 6000 to 8000 ish or when it starts to discolour
The modern oils will last the distance for shore, but the only thing I would watch is if it new and under warrante, just make shore you use genuine filters etc if you do do it
marque is offline
post #4 of 11 (permalink) Old Mar 3rd, 2014, 10:35 PM
mab01uk's Avatar
Quoted: 1 Post(s)
Main Dealer won't change the oil until the computer says so.......if you intend to keep your car long term and wish to look after it and minimise wear and tear then 'old fashioned' shorter oil change intervals are best.
Oils are much improved but longer service intervals save the customers money so are good for manufacturers sales and marketing......
mab01uk is offline
post #5 of 11 (permalink) Old Mar 4th, 2014, 03:41 AM
bmwr606
Local Time: 08:55 AM
Quoted: 2 Post(s)
my usa 03/2012 build cms all4 window sticker said 10,000 mile oil/filter change interval
but, as delivered, the interval was set to 9,000 miles, the obc zeroed out after only 8,000 miles and when the dealer reset the next oil/filter change, it was set to 8,000 miles
when i questioned the SA about it, i was told that was the newest interval per a service notice to the dealers
i do my own oil/filter changes between the OBC changes, and also did one at 1200 and 2500 miles from new
scott
2012 CM S All4 (03/12) | Abs Black w/White Roof/Mirrors/18" White Wheels | Cold Pkg | Sport Pkg | Xenon w/ Black Housings| Manual | Sport Susp| Anth Headliner | Flat Load Floor | Bluetooth | 2 Part Center Rail | Milltek downpipe back exhaust
bmwr606 is offline
post #6 of 11 (permalink) Old Mar 4th, 2014, 11:12 AM Thread Starter
United States Male
White Cooper Happy Engine
scott
Thanx "BMWr606" I have been raised that way and always have changed sooner than later, it's just that the tech in the new oils is amazing compared to even 10-15 yrs ago. No matter what any1 says it's like hell inside a new/tight engine. The wife will say "Why we gotta change it Mike, it's not time" but Ill remind her of her Subaru that went for 120'000 mi with only one real prob. It developed a crack in 3rd gear so we had the gear box pulled and fixed for under $800.00. The oil got changed twice on that car the first 1000 miles of it's life! THANX AGAIN THERE SIR
post #7 of 11 (permalink) Old Mar 4th, 2014, 11:23 AM Thread Starter
United States Male
White Cooper Thanx......
I will change it. The 1st change is so important and another gentleman recommended a magnetic drain plug, never thought of that. So it's off to Mini of Ramsey, NJ to get Oil, Filter, Plug washer and a cup of Coffee from their service area thanx again............
post #8 of 11 (permalink) Old Mar 4th, 2014, 11:25 AM Thread Starter
United States Male
Thank Ya, I shall feel the force do the right thing and change that fresh engine oil!
post #9 of 11 (permalink) Old Apr 18th, 2014, 09:31 AM
Banned
dude i think its too late that you change the oil after 10'000 miles its not good for the engine because you drive the car daily and its demand of the engine that you should change the oil after two weeks..
habi222 is offline
post #10 of 11 (permalink) Old May 7th, 2014, 06:52 AM
Banned
As you know car strength great depends upon the Engine oil.So i recommend you as an mechanic to use a high quality oil so you car pick remains excellent.Its good to change your oil after every 10,000 miles.So it gives you a reliable drive.Excess changing of the oil is also not good for the Mini.Remind it.
habi222 is offline
post #11 of 11 (permalink) Old May 7th, 2014, 06:57 AM
Local Time: 02:55 PM
Quoted: 53 Post(s)
I dont think theres a reason not to change it every day if you want to apart from cost, the engine internals will be cleaner than the cars outside if you do.
The Nun is offline
Coolant leak & Oil usage Zanhar 25 Second Generation Faults & Fixes 15 May 19th, 2014 07:55 AM
Low Oil Pressure - Filter Debris in Oil System??!! MissMac General Discussion 5 Apr 1st, 2013 10:23 AM
Dead Turbo needs replacing in 1.6 dooper Porn_Star19 General Discussion 0 Jan 24th, 2013 10:37 AM
Changing Oil Pan Gasket pablo86 First Generation MINI Cooper S 6 Nov 11th, 2012 05:14 PM
5w30 oil failure suspected ptjenki1961 Maintenance & MINI Care 9 Sep 1st, 2012 01:22 PM
