check engine light 2008s automatic 48k miles - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 5 (permalink) Old Mar 7th, 2014, 02:23 AM Thread Starter
Local Time: 04:28 PM
The check engine light came on today and I took it to my MINI dealer. Dealer says the intake valves are not seating because of carbon buildup. They suggest blasting with walnut shells. I found a gas additive that cleans injectors and intake valves. The dealer says they don't think it will hurt, but not help. The car seems to run fine. Any comments? Dealer says $1100 to clean things up.
rehardwick is offline
post #2 of 5 (permalink) Old Mar 7th, 2014, 06:50 AM
SGT Slaughter & Farm Girl
Local Time: 12:28 PM
United States Male
DIY Walnut Blasting
Hey what's up........
Don't know where your at in the US but I hope this helps. Scroll down on "Mini2" home page to "Community Discussions" look under the NORTH EAST section semi close to the top there are two guys that are certified techs and do the walnut blast for $350.00.
JPAP Motorsports, (718) 440~7666 there names are Austin & James out of East Northport NY
You will see there Posting "Walnut Blasting"
After you get done blasting you may wanna do as I do buy some Royal Purple injector cleaner that should be used every 3rd tank or so. Keeps ya clean and even gives an octane boost. Cost is about 15~20.00. If you can't get to a walnut blaster the Royal Purple will clean you up to some extent and you will run better but will not be cured. The one can wonders we call them IE...... Gumout etc etc you see are not worth much at all and weak! Best of luck Bro
Mini_drive is offline
post #3 of 5 (permalink) Old Mar 7th, 2014, 11:03 AM
United States Male
DIY Sorry, Boo Boo On Section......
YES IT'S UNDER "COMMUNITY DICUSSIONS" THEN LOOK DOWN TO "USA" AND CLICK ON "New York, New England Region" for JPAP Mototrsports.
Guess I was a little hazy that early in the morning!
post #4 of 5 (permalink) Old Mar 7th, 2014, 08:37 PM Thread Starter
NY is quite a few miles from where I am. What I am really concerned about is that the direct injection used is a new technology. Is this something that is inherit with it? The additive I am trying is supposed to clean intake valves.
Cleaning with walnut shell fragments is been around for some time, but the need went away when lead was taken out of gas back in the 1950s in the USA.
post #5 of 5 (permalink) Old Mar 7th, 2014, 09:18 PM
Caveman's Avatar
Local Time: 06:28 PM
Quoted: 83 Post(s)
Carbon build up is common on N14 engine ...
Gas additives to clean intake valves don't work with direct injection engines because gas is injected directly into the combustion chamber.
Dealer quote of $1100 for decoking is outrageous.
Suggest asking over on NorthAmericanMotoring for someone to in your area who does walnut blasting.
Caveman is offline
Check Engine light appear kacik First Generation Faults & Fixes 0 Dec 30th, 2013 01:30 AM
Check Engine Light fortunot General Discussion 4 May 27th, 2013 02:05 AM
Check engine light query morgi27 Maintenance & MINI Care 1 Sep 10th, 2012 05:43 PM
Check engine light on! morgi27 Maintenance & MINI Care 0 Sep 9th, 2012 02:12 PM
