Boot switch not working - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 6 (permalink) Old Mar 8th, 2014, 10:23 AM Thread Starter
Local Time: 08:11 AM
Quoted: 1 Post(s)
Our 2008 One seems to have developed a fault with the boot switch, as in it just doesn't work! The keyfob still opens the boot ok, and you can see the latch working correctly, but the rubber button doesn't work.
I've taken the strip off and had a look but the actual button part looks completely sealed in to the trim strip - plastic welded edges and the rubber cover is not removeable - great for keeping the water out I suppose but means a complete replacement is needed!
Before I splash out on a whole new strip, is there anything else anyone knows of that might cause this, or is it simply just a knackered switch? The lights still work ok so power is getting there.
GoldenWonder is offline
post #2 of 6 (permalink) Old Mar 8th, 2014, 03:05 PM
Quoted: 53 Post(s)
On my old one it was the only item to fail in 4 years of use, the microswitch behind the boot release button, so its probably a failed switch and nothing else like mine was.
The Nun is offline
post #3 of 6 (permalink) Old Mar 8th, 2014, 03:52 PM Thread Starter
Quoted: 1 Post(s)
Cheers - I'm hoping it is just a simple switch replacement (although its not going to be cheap!)
Its the only thing to fail on our 80k mile 2008 mini in the 2 years we'd had it, so I'm not complaining
post #4 of 6 (permalink) Old Apr 18th, 2014, 09:09 AM
Banned
Local Time: 07:11 AM
Sounds like the micro switch latch that operates the boot might be failing if this thing is happen then problem in the boot switch and you have to do that open the popped the switch and repair it from mechanic...
habi222 is offline
post #5 of 6 (permalink) Old Apr 18th, 2014, 11:04 AM
Local Time: 05:11 PM
Quoted: 3 Post(s)
Australia Male
Garage
New Zealand
If you're game to fix it yourself, it will be pretty cheap, otherwise I believe you need to buy the whole trim piece.
Here's the link to how I repaired mine (on my R57)
burnstar is offline
post #6 of 6 (permalink) Old May 13th, 2014, 07:17 AM
Banned
Yeah nice suggestion about this Boot switch.I also advice to change your whole trim piece.Its a better option.It gets better.So its depend on you what you like to do.
habi222 is offline
Clutch switch. Help!! g12__ First Generation Faults & Fixes 4 Jul 29th, 2015 01:09 AM
2007 MCS R56 boot open warning light/message on dash, squeal & rear wiper not working LadyUK Second Generation Faults & Fixes 3 Oct 31st, 2013 05:27 PM
R57 Boot issues villiham General Discussion 2 Mar 28th, 2013 01:44 PM
09 cooper convertible boot lid problems Aysh Second Generation MINI Convertible 4 Dec 3rd, 2012 07:59 PM
mini convertible boot opening problems mase84 First Generation Faults & Fixes 0 Dec 3rd, 2012 06:20 PM
