Electrical Issues with 2003 Cooper base - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 4 (permalink) Old Mar 10th, 2014, 07:09 PM Thread Starter
Local Time: 11:45 AM
Lights behind speedometer do not work. The speedometer itself works fine, I can see it in the daytime. The climate control (A/C and Heat) lights work but the blowers never engage. I checked all fuses, did not replace the relays yet.
The passenger side window does not respond to the switch (may be unrelated). Radio works fine, lights on radio included. Clock works.
Is this definitely an ignition switch issue?
Just bought the car used and I am dumping money into getting it back to 100%.
Thanks,
Casey
caseyc1909 is offline
post #2 of 4 (permalink) Old Mar 14th, 2014, 05:00 PM
SGT Slaughter & Farm Girl
United States Male
Post Some things work others don't...
I really don't know what to tell you but just for my two cents, your troubles sound a lot like the cars I saw in NC that got flooded.
Some things work some things didn't!!!!
I would for sure look at the relays and price em out.
Maybe you can obtain a wire diagram?
Mini_drive is offline
post #3 of 4 (permalink) Old Apr 18th, 2014, 09:05 AM
Banned
Local Time: 03:45 PM
Not sure specifically what you mean by the Battery is perfect if battery is perfect then i think its not issue of the current many be plug is not working well you change the plug i hope your problem is solved...
habi222 is offline
post #4 of 4 (permalink) Old Apr 18th, 2014, 05:29 PM
Local Time: 04:45 PM
Quoted: 53 Post(s)
Just bought the car? Did you try everything on the test drive and they worked then? Is it under warranty? Did you contact the previous owner if the problems were the reason they got shut of it?
Too many people buy a car in a rush then find out its got too many problems that should have been obvious at time of purchase had they spent a little extra time going over it?
Then moan about how much its costing to fix.
The Nun is offline
Electrical Issues on 2003 Mini cooper SafetyMoose Second Generation MINI Cooper 3 Jan 14th, 2014 11:23 AM
2003 1.6 Cooper gearbox issues. Help! Kerr Maintenance & MINI Care 6 Feb 25th, 2013 10:54 AM
2003 Cooper vs Cooper D minioll MINI Cooper Diesel 5 Feb 1st, 2013 02:41 PM
2003 mini cooper electrical problem gauges dont work SafetyMoose First Generation MINI Cooper 0 Jan 17th, 2013 06:39 PM
