Air bag reset tools - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 4 (permalink) Old Mar 16th, 2014, 11:06 AM Thread Starter
Local Time: 04:16 AM
Air bag reset tools
Hello all.
Have been viewing this site as a casual browser, following the other halfs recent purchase of a Mini Park Lane. Have had to fix a couple of things on it, and this place has proved invaluable.
Now I've got the seemingly common problem of the airbag light. I've been looking at the B200 tool to check and reset the light....which is about 49. Have seen suggestions that the B800 will work equally well.....and it's only 16. Is this true? Any other suggestions?
Elisedriver is offline
post #2 of 4 (permalink) Old Mar 16th, 2014, 05:07 PM
Local Time: 05:16 AM
hi
where about you from somebody local to you on this forum might borrow or let you use theres saves buying
i have a airbag reset tool im in cannock staffordshire if that helps
kelv1962 is offline
post #3 of 4 (permalink) Old Mar 16th, 2014, 06:44 PM Thread Starter
Cheers, am near Ipswich.
However I suspect this may be a common occurrence, so having a tool might not be a bad thing? If the B800 does work, it's not bad at 16.
post #4 of 4 (permalink) Old May 20th, 2014, 06:13 AM
Banned
But you can claim it from where you buying it.However its not an expensive tool,you can change it again also.Its not an issue.Good to think.Rather than this you might take of a better quality than this,if it would not works well.
habi222 is offline
Airbag Light and B800 reset tool showing code 1 and 15 Skitos First Generation Faults & Fixes 4 May 20th, 2014 10:19 PM
Air bag light problem wwjd21678 Second Generation Faults & Fixes 0 Feb 10th, 2014 07:28 AM
Air Bag Mini2 air bag light reset resolved ClubUK Welcome New Members 0 Jan 27th, 2014 06:33 PM
Air Bag Light - Wont Reset HELP! ICMINI First Generation Faults & Fixes 3 Dec 29th, 2012 01:14 PM
air bag light ,,any help where to go? charmingman General Discussion 2 Aug 15th, 2012 01:11 PM
