Can I use different of grades of gasoline when refueling my mini cooper? - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 12 (permalink) Old Mar 17th, 2014, 01:14 AM Thread Starter
Local Time: 06:20 PM
Hi everyone,
I am in CA, U.S. I just purchased a 2013 Mini Cooper Hardtop.
I am a new driver so I know little about cars ...
The dealer told me that I should add AKI 89. I looked up the manual and it says that AKI 89 is the minimum while AKI 91 is recommended.
I heard that if I use higher grade gasoline, my Mini would perform better. If this is true, I would like to switch to 91 in the future.
Someone told me that if I want to add 91 while there is still 89 in the tank, I need to get rid of the 89 first ... Is it true? Can't they both be in the same tank?
Thank you!
fay_sd is offline
post #2 of 12 (permalink) Old Mar 17th, 2014, 08:53 AM
Local Time: 02:20 AM
Quoted: 53 Post(s)
The higher the octane the better for a petrol MINI
If you have low octane in the tank now, just fill up with the higher premium grade then keep using that, no need to run the lower stuff right out first.
The Nun is offline
post #3 of 12 (permalink) Old Mar 17th, 2014, 11:56 AM
Local Time: 01:20 AM
Quoted: 39 Post(s)
I think the answer depends on which model of Cooper you have. A Cooper S will respond to better petrol/gas, whereas in a plain Cooper it's hard to tell any difference.
One thing to watch out for is that this is a mainly British forum and British octane/AKI numbers are different from US ones - so someone may come along and say you need 99 octane but that would only be 95AKI!
I wonder if the advice not to mix the fuels was so that you could tell if they perform differently - if you mix the grades, the change may be too subtle to notice.
Angib is offline
post #4 of 12 (permalink) Old Mar 17th, 2014, 03:46 PM
SGT Slaughter & Farm Girl
Local Time: 09:20 PM
United States Male
Post 89 Octaine........
The wife and I used 89 the whole 58'000 miles we had our 09 HardTop non turbo. You do hear some knocking once in a while but the manual said 89would not hurt anything in the engine. Never had one ounce of trouble....
We have ordered a 2014 Countryman S All-4 from Mini. We will use 91, 92 octane in that, the Turbo really needs it.
If you just take a look at fuel prices next time you go to fill up just take the gallons your car took and times it by the higher octane price, it is only a couple dollars more.
IE...... 10 gal X 3.35 a gallon = $33.50
(here for 92 it's $3.52)
10 gal X 3.53 a gallon = $35.20
Happy Motorin, Mini's are awesome............
Mini_drive is offline
post #5 of 12 (permalink) Old Mar 17th, 2014, 06:42 PM Thread Starter
Great thanks to all of you
fay_sd is offline
post #6 of 12 (permalink) Old May 20th, 2014, 07:00 AM
Banned
Yeah everyone gave us a value able information about the gasoline.Higher the octane number higher the life of a car.So i would like to use every time high octane number gasoline on my Mini Cooper.Nice suggestion i got from this thread.
habi222 is offline
post #7 of 12 (permalink) Old May 25th, 2014, 12:12 AM
Canada Male
I agree, give it the 91 it deserves. Treat it well and it will reward you back. In the end, it's only a couple of bucks per tank. Peace of mind = priceless.
ilovecables is offline
post #8 of 12 (permalink) Old Jun 18th, 2014, 11:01 PM
United States Male
Fuel octane & turbo charger.
Fuel octane and turbochargers, one does not influence the other, that is misinformation.
steeleyscotty is offline
post #9 of 12 (permalink) Old Jul 7th, 2014, 12:41 PM
Canada
Canada Fuel Type in Canada
Hi there,
*I want to know which type of fuel should I use for my 2009 Mini Cooper?
*I want to know which brand should I use for my 2009 Mini Cooper?
(ie: Shell, Esso, PetroCanada)
It's been a month since I've stopped using Regular 87 at PetroCanada, & I have been running my Cooper on "Ultra 94" from PetroCanada (so far 2-3 refuelling times)
I just want to keep my car healthy & well fed
I appreciate your advice and feedback.
Thank you very much
JARL13 is offline
post #10 of 12 (permalink) Old Jul 7th, 2014, 05:42 PM
Quoted: 39 Post(s)
The important question is whether you have a Cooper or a Cooper S, as it seems to be only the S model that benefits from better fuel.
As you are in Canada, I believe you use AKI fuel ratings, not the RON ratings we use in Britain. So before any Brit says 'Ultra 94' doesn't sound very good, it has a RON rating of 101.5. Dammit, that's nearly rocket fuel and a far higher grade than any that can be bought here.
Angib is offline
post #11 of 12 (permalink) Old Jul 7th, 2014, 09:49 PM
Canada
Canada @Angib
Standard Mini Cooper Hatch 2009 R56 - to answer your question.
I just want to keep my Mini Cooper well fed and healthy
You are correct we use AKI fuel ratings. "Ultra 94" from PetroCanada; I couldn't add the weblink so I copy and pasted the features of Ultra 94 below:
__________________________________________________ _________________________________________________
Ultra 94, the High Octane Advantage
Ultra 94's high octane formula surpasses the CGSB (Canadian General Standards Board) performance requirements for super premium gasoline.
What does this mean for your vehicle? Ultra 94's unique performance and higher detergency helps to:
Clean your car's fuel injectors and intake valves — and keep them clean
Optimize fuel economy
Reduce emissions
Improve overall vehicle performance year-round
Ultra 94's higher octane helps ensure you get maximum horsepower, acceleration and performance from your vehicle, even under tough
driving conditions.
Gasoline
Petro-Canada™ produces and sells high quality gasolines designed to meet every type of Canadian driving condition.
Petro-Canada offers three grades of gasoline across Canada, and a fourth grade in selected areas:
Grade
Octane Level
Petro-Canada Brand Name
Regular
87 octane
RegularClean
Mid-grade
89 octane
PlusClean
Premium
91 octane
SuperClean™
Super premium
94 octane
SuperClean 94, available in Montréal
Super premium
94 octane
Ultra 94™
All Petro-Canada branded gasolines contain Tactrol™, a proprietary deposit control additive, sometimes called a gasoline detergent, that is designed to keep fuel systems clean.
Petro-Canada has supplied Canadians with high-quality fuels that meet their driving needs for many years. This track record, and the fact that our fuels meet or exceed all Canadian standards, has resulted in our customers’ confidence in the quality of our fuels. To confirm the high standards of our fuels, Petro-Canada decided to participate in the Top Tier program as of Oct. 1, 2006.
Find out how Petro-Canada uses ethanol-blended gasoline in selected markets
Tactrol
Because A Cleaner Engine Simply Runs Better
Tactrol is our exclusive deposit control additive that acts as a detergent to clean and prevent the build-up of harmful deposits. Tactrol is used in all grades of Petro-Canada gasoline — including RegularClean, PlusClean, SuperClean, Ultra 94, and WinterGas™.
SuperClean and Ultra 94 come fortified with an extra dosage of Tactrol — so it can actually remove stubborn deposits, help restore your engine's performance, and keep it clean.
No other company uses Tactrol except Petro-Canada.
JARL13 is offline
post #12 of 12 (permalink) Old Aug 7th, 2014, 07:37 PM
Canada
Canada
Thanks for the great advice on this thread.
I'm Canadian too Jarl15 and I jam gassing up my 2014 Mini Cooper Hardtop with Supreme 94 (AKI 94) from Chevron, it's my gas station of choice. This is my first MINI, but I have never had issues with my previous cars when it came to using Chevron gas. I will provide an update on the fuel effiency as I just gassed it up with a full tank this morning since taking delivery on July 25th. I took delivery with a full tank of gas, courtesy of the dealership, but ran through it pretty quickly as you can imagine my excitement in getting the car I was goign on drives to get used to it. Now that I am settling into my normal routine I am curious to see how long this tank of gas will last me.
NewbieMINI is offline
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 15 Apr 23rd, 2015 04:15 PM
2014 MINI Cooper S Revealed in Spy Photos AutoGuide.com MINI News 14 Jan 13th, 2015 08:58 PM
Mini HQ - Terrible ethics for the customer. jobforacowgirl Dealership Feedback 11 May 22nd, 2014 06:36 AM
Brooklands Mini Day Sunday, March 24, 2013 mab01uk Mini Events 11 Apr 5th, 2013 07:11 PM
Mini Australia service chilld Dealership Feedback 4 Sep 4th, 2012 06:29 AM
