R50 Cooper - Getrag 5spd - which gearbox oil please?! - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 8 (permalink) Old Apr 11th, 2014, 06:05 PM Thread Starter
Local Time: 09:40 PM
Wales
Question R50 Cooper - Getrag 5spd - which gearbox oil please?!
Hi all,
I've a R50 Cooper, Getrag 5 spd 'box.
I need to change the gearbox oil, but have no clue as to what I should use.
I've searched high and low on forums, but too many answers and reasons to make head nor tail of.
What oil do I need to buy? Which oil makes the box silky smooth?
That's all I need to know really.
Many thanks in anticipation of your help.
Impster
impster is offline
post #2 of 8 (permalink) Old Apr 11th, 2014, 10:35 PM
Hi ya
Hope this helps
http://www.mini2.com/forum/first-gen...-mtf-94-a.html
marque is offline
post #3 of 8 (permalink) Old Apr 12th, 2014, 08:50 AM Thread Starter
Wales
Going to order Redline ATF D6 as this seems to be the stuff that matches BMW's specification for a 5speed Getrag on an R50 cooper.
impster is offline
post #4 of 8 (permalink) Old Apr 12th, 2014, 12:39 PM
BLIKSEM (my brg/brg mc)
cristo's Avatar
Local Time: 05:40 PM
Quoted: 25 Post(s)
United States Male View cristo's British Racing Green & Body Color 1st Gen MINI Cooper Profile
Garage
correct
cristo is offline
post #5 of 8 (permalink) Old Apr 12th, 2014, 01:48 PM Thread Starter
Wales
Thumbs up
Originally Posted by cristo View Post
correct
many thanks.
Minis are new to me, I've only just bought one so am very grateful for any advice that helps me keep it at it's best.
impster is offline
post #6 of 8 (permalink) Old May 8th, 2014, 07:08 AM
Banned
Yeah these suggestion are better to change the gear box oil.I am a mechanic by profession and many times changing this oil in my Mini Cooper.But i used always a high quality for its perfection.You can get it from any automotive shop.If you want to know some internal about the cars model,engine number etc so visit vin decoder toyota.It helps you.
habi222 is offline
post #7 of 8 (permalink) Old Feb 17th, 2015, 04:35 AM
transmission replacement required
i have a 2003 mini base model with the midland 5 speed manual gear box. is there a getrag transmission that will fit, such has the 2004 or 2005 models
Tony Laing is offline
post #8 of 8 (permalink) Old Feb 17th, 2015, 01:15 PM
cristo's Avatar
Quoted: 25 Post(s)
Garage
You can put in the 5-speed Getrag from the 2004-2005 models, but you will also
have to change a lot of other stuff - clutch, flywheel, mounts, axles, starter, clutch lines,
shifter and cables, etc. If you're going to do all that, you might as well go for a
Getrag 6 speed from the S - you have to change all of the above for that, too,
and although a 6-speed Getrag is more expensive than a 5-speed Getrag, with
all the extra stuff the bottom line isn't that much different proportionally.
If you do go for the 6-speed, get the later BKE(without LSD) or BKL (with LSD) 6-speed
from 7/2004-2006 as it has better gear ratios for the R50 than the earlier BKA one .
Also, check out this link (pdf article on the swap).
http://personal.stevens.edu/~jdunn/F...heWeakLink.pdf
cristo is offline
Cooper 5spd getrag gbx diff bearings? kieranm First Generation MINI Cooper 1 Feb 19th, 2014 11:02 PM
Oil question, 52 plate mini cooper S, help a newbie! Lisaa-wilson General Discussion 11 Nov 29th, 2013 11:34 PM
Gearbox Oil confusion. spikeyadrian First Generation Faults & Fixes 5 Apr 29th, 2013 09:11 AM
Low Oil Pressure - Filter Debris in Oil System??!! MissMac General Discussion 5 Apr 1st, 2013 10:23 AM
2006 Cooper R50: Oil and Tire Pressure rphox2003 First Generation MINI Tuning 3 Mar 16th, 2013 02:46 PM
