Diagnostic codes - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 2 (permalink) Old May 1st, 2014, 09:22 PM Thread Starter
Local Time: 04:43 AM
Diagnostic codes
Hello, can anyone help me...
Ive just had diagnostic tests run on my 2001 Mini one and it has come up with Code 10 - firing circuit battery safety switch 2 and
Code 5 - firing circuit safety airbag front left side
Does anyone know how to resolve these problems without having to take it to BMW/Mini to fix? Any help would be great!
Thanks!
Tbull422 is offline
post #2 of 2 (permalink) Old May 1st, 2014, 10:38 PM
heathwebbo's Avatar
I take it you had the diagnostic done for the airbag light staying lit ? A common problem on the early minis is the wire connectors under the passenger seat, some people unplug them clean them up replug them together & its ok others remove the plug & solder the wires together, either way it will need resetting after the problem has been sorted
heathwebbo is offline
Tags: , ,
Self Diagnostic Code / Fault Reader Interpretation lindol First Generation Faults & Fixes 0 Mar 5th, 2013 01:40 PM
Error Codes 2007 Mini Cooper S LadyUK Second Generation MINI Cooper S 1 Jan 22nd, 2013 02:39 PM
