Emergency! Please help - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 7 (permalink) Old May 5th, 2014, 01:11 PM Thread Starter
Local Time: 09:17 PM
Ireland
Please help,my wipers have stopped working and Im on a motorway in the lashing rain, had to pull in as I cant see a thing. They work for around 10 seconds when I re-start the car and then stop.
hats199 is offline
post #2 of 7 (permalink) Old May 5th, 2014, 01:23 PM
Local Time: 08:17 PM
Hi ya
Is you mini a first generation or second generation.
I take it the don't work on any speed or even if you pull the stalk back to wash the screen.
It sounds like it might be a relay but if you know what generation it is we might be able to help abit more
marque is offline
post #3 of 7 (permalink) Old May 5th, 2014, 01:28 PM Thread Starter
Ireland
Its first gen, post facelift. The screen wash is working, its works at some speeds, but only for a few seconds and then gets stuck. Disaster.
hats199 is offline
post #4 of 7 (permalink) Old May 5th, 2014, 01:32 PM
Ok
Sorry when you sat it gets stuck does it stop half way across the screen or goes back to the park possition then fails
marque is offline
post #5 of 7 (permalink) Old May 5th, 2014, 01:35 PM Thread Starter
Ireland
Gets stuck halfway across the screen
hats199 is offline
post #6 of 7 (permalink) Old May 5th, 2014, 01:46 PM
Ok sound a like it might be the motor or a relay.
But relay is an easy
If you open the bonnet on the right hand side as you look at it between your battery and the strut tower there is a black fuse box.
Open it up and at the back of it on the right hand side there are two black relays.
There the wiper ones you can try changing them around and try it
I will just find a picture so you know what ones I am talking about.
Check that the fuse box is dry as well there is also a fuse there to right hand side row of fuses no 9. No1 being the closest to the front of the car make shore it's ok and pushed in
Just going to get a picture of the fuse box
marque is offline
post #7 of 7 (permalink) Old May 5th, 2014, 01:49 PM
Here the relay panel
Try swapping relays A and B around
marque is offline
MCS Engine noise when cold CBCooper Second Generation Faults & Fixes 2349 Mar 30th, 2016 10:09 PM
