Help - what does this symbol mean ? - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 8 (permalink) Old May 9th, 2014, 05:13 PM Thread Starter
Local Time: 02:54 AM
Could some kind person tell me what this code means ?
I have just had the front brake pads changed at my local garage (not Mini)
The car was bringing up the service light for the brakes and it was telling me that there were 370 miles left in the pads.
The garage has obviously re-set that but not when I put my key in it says this:
It doesn't need a service so what is it ?
thanks
Justa is offline
post #2 of 8 (permalink) Old May 9th, 2014, 05:23 PM
Local Time: 01:54 AM
Quoted: 40 Post(s)
Well, that's a diagram of the rear of a Mini and the brake symbol, so it's saying that your rear brake pads (and maybe discs too) need to be replaced in about 1100 miles.
Angib is offline
post #3 of 8 (permalink) Old May 9th, 2014, 05:25 PM Thread Starter
oh blimey thanks
Erm the pads look fine and didn't get bought up in its service in February !
Is it possible the garage have cocked it up ?
Justa is offline
post #4 of 8 (permalink) Old May 9th, 2014, 06:20 PM
Quoted: 40 Post(s)
1100 miles to go is an 'iffy' stage. At several thousand miles to go, the car is guessing how long, based on typical data it is programmed with. At a few hundred miles to go, it is pretty accurate as the wear sensor has been triggered. I'm not sure if at 1100 miles to go the wear sensor has been triggered, so I'm not sure if it is a reliable warning. I would wait until it gets to 500 miles before believing it.
I swapped the front brakes on my SD for S brakes and the service indicator is now having nightmares - it got as low as 1600 miles but is now counting upwards past 2000 miles!
Angib is offline
post #5 of 8 (permalink) Old May 9th, 2014, 09:27 PM Thread Starter
Much appreciate your help - typical that it needs rears after just replacing the fronts !
Justa is offline
post #6 of 8 (permalink) Old May 10th, 2014, 06:50 AM
Quoted: 53 Post(s)
Perhaps youve done a lot of reversing recently?
The Nun is offline
post #7 of 8 (permalink) Old May 10th, 2014, 09:25 AM
Quoted: 40 Post(s)
Actually this is quite logical and shows the CBS system is 'thinking' correctly.
It expected me to trip the wear sensor some time ago (since the system didn't know that I had swapped the brakes at 5,000 miles or so) and because that didn't happen, it is extrapolating from how long I've already driven - so the longer I go before tripping the wear sensor, the longer it will predict until I need to replace the pads.
x + y = z , I think......
Angib is offline
post #8 of 8 (permalink) Old May 16th, 2014, 06:36 AM
Banned
Yeah man you right,its a logical CPS system introduced by BMW for Mini.Its easy to understand but by the professional in car field but not understanding well by a local person.Nice to talk about it.If you want to know more about the cars and their specs so have a look on BMW VIN Decoder.It helps you a lot.
habi222 is offline
Warning symbol mini_betty Second Generation Faults & Fixes 8 Feb 20th, 2015 10:29 PM
What is this warning symbol in the service menu? minifan10 General Discussion 2 Nov 24th, 2013 09:04 PM
Mystery warning symbol? Mid Life Mini Second Generation Interior & Ice 1 Jun 30th, 2013 10:46 AM
Scary dashboard symbol McrMini Second Generation Faults & Fixes 6 Mar 5th, 2013 05:48 AM
