Knocking from rear wheel - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 6 (permalink) Old May 16th, 2014, 08:20 PM Thread Starter
Local Time: 09:56 AM
Hi guys i have a rythmic knocking /ticking noise coming from the rear drivers side wheel seems to stop when the brakes are applied sounds like the pads are rattling round if that makes sense had a quick look at the wheel the bearing seems ok the cars a 51 reg cooper hope someone can help also the front wishbones seem noisy so im replacing both sides and the bushes is this do able at home does the subframe have to come conpletley off sorry for all the questions thanks in advance keith
Keithys is offline
post #2 of 6 (permalink) Old May 16th, 2014, 09:05 PM
Hi ya
Rear knocking sounds like the rear anti roll bar bushes.
Easy job just get both back wheels of the floor to unload the anti roll bar two bolts each side on the clamp pull out the bushes fit new refit clamp job done, it takes longer to get the wheel on and off :-)
The front wish bone bushes can be done with out taking the sub frame out. I just unbolted it and dropped it down at the back and pulled them out it's tight but it's ok,
I bought the complete bracket and bush it was about 10 more but you will not need a tool to push the bush out and new back in.
If you are going to replace just the bush get a set of these from rich at orranje
Whiteline - Front wishbone rear bush - Orranje - New MINI Performance & Styling Products
While your there replace the anti roll bar bushes to.
Hope this helps
marque is offline
post #3 of 6 (permalink) Old May 16th, 2014, 09:51 PM Thread Starter
Brill thanks mate yeh helps a lot i will take a look tomorrow
Keithys is offline
post #4 of 6 (permalink) Old May 16th, 2014, 10:49 PM
marque is offline
post #5 of 6 (permalink) Old May 16th, 2014, 11:06 PM
Quoted: 25 Post(s)
check for loose wheel nuts
drozd is offline
post #6 of 6 (permalink) Old May 17th, 2014, 01:12 AM Thread Starter
Brill thanks guys
Keithys is offline
Knocking from rear wheel Keithys Maintenance & MINI Care 0 May 16th, 2014 07:47 PM
Knocking from rear?!?! Choppa General Discussion 3 Sep 29th, 2013 09:02 AM
strange knocking from rear end tomo41 Second Generation MINI Cooper S 1 Apr 28th, 2013 09:52 AM
knocking noise from passenger left rear side dessieb123 MINI Cooper Diesel 1 Dec 18th, 2012 08:29 AM
HELP - Rattle/ Knocking Noise from rear passenger side wheel. thegreensnot Second Generation Faults & Fixes 8 Dec 10th, 2012 08:21 AM
