Power Steering Hose Replacement 450!!! - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 2 (permalink) Old Jun 3rd, 2014, 06:46 PM Thread Starter
Local Time: 10:13 AM
DIY Power Steering Hose Replacement 450!!!
Just got back from the dealer after a check up and have been advised that my power steering hose is leaking (not badly apparently). Was told it was a big job to replace and then quoted 450!! Is this correct??? I wouldn't mind but I only now drive it twice a week. Its a 2008 Mini Cooper Sidewalk with 28,000 on the clock. Bought it at 15,000 miles and had so many problems in the first year (all sorted under warranty) - engine bracket split, roof leaking, air con failure to name a few. I just wondered if this is just normal for a mini of this age and mileage or did I get a lemon?? Also if anyone has had the hose work done and what you were charged. Is it worth going somewhere else i.e. non Mini dealer?
Thanks all, much appreciated.
KR
KillashandraRee is offline
post #2 of 2 (permalink) Old Jun 4th, 2014, 12:01 AM
mab01uk's Avatar
Local Time: 09:13 AM
Quoted: 1 Post(s)
Try a good recommended local independent garage, the hose is not difficult to replace and labour rate will be a lot cheaper.
If you give your approx. location someone may even be able to recommend an independent Mini specialist near you.
mab01uk is offline
Tags: , , ,
power steering pump & fan replacement Qs canucklehead First Generation MINI Cooper S 2 Jun 7th, 2014 01:59 AM
Power Steering Rack & Pinion Frustration VerticalMinded First Generation MINI Suspension 4 Jan 28th, 2014 09:14 PM
Need advise on power steering failure aioxen First Generation Faults & Fixes 11 May 28th, 2013 03:33 PM
Power Steering problems :( Shelley B First Generation MINI Cooper S 5 Feb 15th, 2013 01:13 PM
Power Steering pump on the blink...? cooper357 First Generation Faults & Fixes 8 Aug 21st, 2012 11:26 PM
