power steering fan - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 2 (permalink) Old Jun 5th, 2014, 09:31 AM Thread Starter
Local Time: 07:41 PM
power steering fan
when is my ps fan sopose to turn on? at a certain temp , constantly ? and is it so pose to sound loud?
mikeyp226 is offline
post #2 of 2 (permalink) Old Jun 5th, 2014, 12:30 PM
Local Time: 01:41 PM
Quoted: 119 Post(s)
Australia Male
Garage
The EHPS cooling fan is activated by the EMS when the engine temp reaches 122C (251F) which is the High Speed fan stage on the Engine cooling fan. Once the Engine Temp drops by 4C (7F) then the High Speed circuit stops and the engine cooling fan then reverts to the Low Speed circuit resulting in the EHPS cooling fan stopping.
The EHPS Cooling fan is not connected to the EHPS pump, the pump will shut down if it reaches a set temp to protect its electronic control circuit.
Hope this helps
Ref: Mini Cooper Diagnosis Without Guesswork, Bentley Publishers.
Milpol is online now
power steering pump & fan replacement Qs canucklehead First Generation MINI Cooper S 2 Jun 7th, 2014 01:59 AM
Power Steering Fluid - Alternative leethallee Maintenance & MINI Care 0 Feb 5th, 2014 12:08 AM
Power Steering Rack & Pinion Frustration VerticalMinded First Generation MINI Suspension 4 Jan 28th, 2014 09:14 PM
Power Steering problems :( Shelley B First Generation MINI Cooper S 5 Feb 15th, 2013 01:13 PM
Power Steering pump on the blink...? cooper357 First Generation Faults & Fixes 8 Aug 21st, 2012 11:26 PM
