Chain tensioner - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 2 (permalink) Old Jun 22nd, 2014, 03:30 PM Thread Starter
Local Time: 02:02 PM
DIY Chain tensioner
Hi I was wondering if anyone has had this problem before,
I have removed the timing chain tensioner blanking plug and
Can see the tensioner but I can't remove it , I've tried magnets
And picks to try and get the tensioner out but it won't budge, a friend
Did mention trying to heat the block but not keen as this could weaken
It, is there a set way of getting them out? Any help on this would be great
Ads1989 is offline
post #2 of 2 (permalink) Old Jun 22nd, 2014, 04:28 PM
Hi ya
If your talking gen 1 mini
There are a few more ways you can try
1) turn the engine backward this will pull the chain tight and should put it the tensioner out
2) take of the rocker cover and use a thin bar to push against the chain guide that's how you can reset them installed.
3) take off the oil pump cover and push it back from there just remember if you do it this way to use new orings on the oil gallery's
Hope this helps
marque is offline
2007 Cooper S "Timing Chain Tensioner Defect" igooba Australia 24 Sep 26th, 2016 09:04 AM
Mini Cooper S R56 Timing Chain Tensioner Mini Cooper S BUSTED Second Generation Faults & Fixes 23 Sep 4th, 2015 04:24 PM
MCS Timing Chain Tensioner A18XVM First Generation Faults & Fixes 12 Jul 8th, 2015 06:39 PM
Time Chain Tensioner failure and Engine shut down jhl2435 Second Generation Faults & Fixes 2 Mar 1st, 2014 07:45 PM
2007 Cooper S "Timing Chain Tensioner Defect" igooba General Discussion 1 Feb 14th, 2014 09:40 AM
