2005 Cooper S squeaky clutch. Help. - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 5 (permalink) Old Jul 3rd, 2014, 11:10 PM Thread Starter
Local Time: 05:50 PM
Question 2005 Cooper S squeaky clutch. Help.
Just bought a 2005 MINI Cooper S. It's got 51,000 miles on the clock. I didn't notice it on the test drive or on the way home but the clutch squeaks when I press the pedal. The pedal feels a little bit heavy but otherwise smooth up and down, the gears also go in fine. What causes this problem and what has to be done to fix it? I have a 30 day warranty from the dealer I bought it from (not an official mini dealer) and I'm worried it won't cover a new clutch should I need one.
Noise...
youtube.com/watch?v=Hsump9u3lv8
robross1992 is offline
post #2 of 5 (permalink) Old Jul 4th, 2014, 01:03 AM
Caveman's Avatar
Local Time: 06:50 PM
Quoted: 83 Post(s)
A heavy clutch is normal on 1st Gen Cooper S models.
Caveman is offline
post #3 of 5 (permalink) Old Jul 4th, 2014, 07:26 AM
heathwebbo's Avatar
Local Time: 04:50 PM
If the squeeking is coming from inside the car it will be the pivot point at the top of the pedal as they dry up, you will probably notice it more if your driving for a while & using the clutch a lot. All I did with mine was spray the pivot point & spring (a bit awkward to get at) with spray gease & it hasn't made any noise since
heathwebbo is offline
post #4 of 5 (permalink) Old Jul 4th, 2014, 11:17 AM Thread Starter
It's coming from somewhere in the engine. The local MINI garage said it was just a linkage that either needs lubricating or replaced if it's coming to the end of its life. I still have 3 weeks of warranty left from the place I bought it so I'm hoping they'll sort it, otherwise MINI quoted me 150 just to strip it and have a look.
post #5 of 5 (permalink) Old Jul 4th, 2014, 05:18 PM
heathwebbo's Avatar
The clutch is hydraulic so their isn't really any linkage, the only parts that move on the outside of the engine is the slave cylinder rod which pushes the clutch arm, the clutch arm has a pivot point I suppose that could be squeaking I can't picture it at the moment but I think that is inside the bell housing & all the other parts are internal too
Tags: , , , ,
Clutch 2005 Mini Cooper S capacitytube First Generation Faults & Fixes 2 May 16th, 2014 04:50 PM
Cooper S R56 clutch problems (Lincs) mnemo2002 Second Generation Faults & Fixes 1 Apr 9th, 2013 04:05 PM
2012 Cooper S clutch ellabean69 General Discussion 6 Nov 24th, 2012 02:46 PM
2006 Cooper S Steering & Clutch ciire First Generation Faults & Fixes 5 Nov 15th, 2012 11:28 AM
