Speedo change - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 3 (permalink) Old Aug 13th, 2014, 09:53 PM Thread Starter
Local Time: 06:18 PM
Speedo change
Hi new to the fourm have a 2002 cooper which has a speedo reading nearly 10mph out . I am going to change the speedo for a ebay buy , will the mileage switch over to new speedo and does the new speedo need any coding etc to work .
sam138 is offline
post #2 of 3 (permalink) Old Aug 13th, 2014, 10:35 PM
Local Time: 05:18 PM
Quoted: 39 Post(s)
If your speedo is reading high, that's normal for Minis. Indicated speed typically up to 10% faster than true speed is about usual, so 10mph is more than that. You shouldn't be surprised if the replacement speedo is exactly the same.
Angib is offline
post #3 of 3 (permalink) Old Aug 14th, 2014, 07:06 AM Thread Starter
My speedo needle sits at 6 o'clock not at 0 mph and when doing 10mph on my speedo I'm doing 20mph . Not good want to get it sorted before I get a speeding ticket .
sam138 is offline
Speedo and tach gauge face plate change karlos9191 Second Generation Interior & Ice 1 Jul 30th, 2014 08:31 AM
Manual speedo in automatic car!! Zippy34 First Generation Faults & Fixes 3 Mar 28th, 2014 11:26 PM
Constant beep from speedo and battery going flat????? bigbenn36 First Generation Faults & Fixes 3 Mar 25th, 2013 11:26 AM
Rattle in speedo Ken White Second Generation Works 8 Jan 11th, 2013 08:27 PM
How to change miles between service grayfox Maintenance & MINI Care 6 Dec 9th, 2012 07:27 PM
