2004 Mini Cooper S overheating - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 2 (permalink) Old Aug 13th, 2014, 10:15 PM Thread Starter
Local Time: 12:38 AM
My 2004 Mini Cooper S is overheating and I don't know why? I turn on the the car and let it Idle. After 10 min the overflow tank starts to boil making a popping sound. The temp guage starts to rise and I shut it off. I changed the thermostat didn't work. Took the head off and the gasket looked new. I had the head checked and it was milled and didn't have any cracks. The head got the OK from the head shop. So I put it on, and it still did the same thing. There is no water in the oil and nothing coming out the tail pipe. There is no leaks at the water pump. I checked the radiator next and its OK. What can be causing it to overheat?
ccannedy is offline
post #2 of 2 (permalink) Old Aug 13th, 2014, 11:31 PM
mab01uk's Avatar
Quoted: 1 Post(s)
Check all air is bleed out the system including the heater circuit......this takes time and patience, many threads on this if you search Mini2.
Also check the stage 1 fan is coming on.....it often fails and goes to stage 2 at higher temperature but too late to stop overheating.
More ideas here:
Solving MINI Cooling Problems.......... - Mini Cooper Register Forum
mab01uk is offline
Steve McQueen's Mini Cooper S mab01uk MINI in the Media 4 Aug 28th, 2016 05:27 PM
CVT Transmission Failure slaybalj First Generation CVT & Automatic 143 Jun 10th, 2016 02:24 AM
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 15 Apr 23rd, 2015 03:15 PM
New 14 plate Mini Cooper SD Coupe Nightmare Kickboxkel Welcome New Members 7 Apr 4th, 2015 12:33 PM
Mini Cooper S Seat Heater Fire Paul.Armstrong First Generation Faults & Fixes 0 Apr 29th, 2014 02:08 PM
