Hello everybody.I ve just bought a Countryman S and i have to change the AGM battery.I tried to finf any possible information on this thread and i found only one guy who had replaced the old Mini(original) battery with an identical(Varta 175 euros)but not Mini.The problem is the registration of the battery in the car s software.There is a hugeeee difference in the price of these 2 batteries and i m trying to avoid the original one(300 euros).Is there anyone else who had tried this ?Thnaks.
The AGM battery is always more expensive. Although a standard battery will fit the car, I would resist the temptation to do it just to save money.
AGM batteries were used on 'in car' installations and don't leak acid if the car is rolled etc. The registration is a pretty simple thing, and you could probably have that done separately if you want to fit the battery yourself perhaps.
You can but AGM batteries from motor factors like Euro Car Parts, just confirm to them it is one. I personally, would charge it before fitting with a trickle charger.
You misunderstood what i said.I ll put on an AGM battery of Varta which is exactly the same as the Mini Varta but the problem is that you have to do the registration after that...Can i avoid that?
I don't think you should avoid it, If I remember correctly, certainly with the bigger BMW's, the car adapts to the ageing of the battery, and alters the charging according to that, something like that. If you ignore registration, the car could be treating your battery as an older one, and shorten the life of it. It's not an expensive task, and an indy with Autologic can do it if you don't want BMW to.
Related Threads
MINI Cooper Forum
3.6M posts
159.9K members
Since 2001
