Pressure washers - good or bad? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 11th, 2003, 07:16 PM
Hat's Avatar
Hat
ITS RAINNIN' SIDEWAYS
Local Time: 11:30 AM
England Male View Hat's Classified Ads
the hand-held high pressure washers you can buy from halfords & B&Q seem to be growing in popularity but are they a good idea for cleaning your pride & joy? the pressure they put out is very high & it seems to me that they would strip wax off at best & damage paint at worst. These things can strip a years worth of mildew & moss off concrete in one pass.
Does anyone have any experience of using these? is the pressure variable on the better ones?
Old Apr 11th, 2003, 07:30 PM
Kev'sCoop's Avatar
Local Time: 10:30 AM
Scotland View Kev'sCoop's Chili Red & White 1st Gen MINI Cooper S Profile
I have got one and i have had no probs. Its variable and i got it on ebay new for £40. It actually seems to make the wax more defined just make sure you use a good quality wax shampoo and wax it afterwards. I have used on mines since the start with no probs.
kev
Old Apr 11th, 2003, 11:53 PM
Dark Silver S's Avatar
Ultimate Stealth Machine
Local Time: 04:30 AM
I'd be very careful using a pressure washer on a car finish, if I were you. I've seen them actually eat away wood when held in one spot too long.
Dark Silver S
http://revorg.org/images/mmg.gif
Now in Wilkes County NC
Old Apr 12th, 2003, 12:36 AM
tip's Avatar
tip
Motor On!
Local Time: 05:30 AM
Canada View tip's British Racing Green & White 1st Gen MINI Cooper Profile
I have had pressure washer blow the clear coat clean of the bonnet of the car. A small rock chip was all that it took. The water entered at this point. Working itself between the clearcoat and the paint. It only took a fraction of a second. I still use pressure washers keeping the nozzel at least 1 meter away.
Becareful,
Charles
BRG/W MCS bonnet stripes ,white wheels, sport package, sunroof, heated seats, Alta pulley, Alta intake
Old Apr 13th, 2003, 04:53 AM
lightbody's Avatar
Send a message via ICQ to lightbody Send a message via MSN to lightbody Send a message via Yahoo to lightbody
Scotland Male View lightbody's Chili Red & Black 1st Gen MINI Cooper Profile
Just dont point the jet at the vents in front of the windscreens - you can blast away the foam mesh covering the vents.
Rob Lightbody - http://www.roblightbody.com
2004 Red/Black Cooper replaced a 2001 BRG/White Cooper
Old Apr 13th, 2003, 05:06 AM
ScooterMan's Avatar
United States View ScooterMan's Pepper White & Body Color 1st Gen MINI Cooper Profile
I would never use a pressure washer on a car. A gentle washing is much better or even a brushless car wash.
Pepper White / Red Interior / Red Stripes / CVT
Talk is cheap 'cause supply exceeds demand.
Old Apr 13th, 2003, 05:01 PM
Don't do it.
2003 MCS All Black
1992 NSX Red/Blk 5 spd #0330
1974 Vette 454 4 spd Wht/Blk
1976 Honda Accord 5 spd, 3 door Blue/Blue
Old Apr 14th, 2003, 09:46 PM
GordonD's Avatar
Local Time: 06:30 AM
Scotland View GordonD's Dark Silver & White 1st Gen MINI Cooper S Profile
Mine got a huge workout this weekend blasting all the cruf out from wheelwells etc.
I use the fine spray head for actually washing the car. I have checkered roof and worry that the high pressure will lift them off.
aka KWKSLVR
Member:
Southern Ontario MINI Club
BMW Club of Canada - Trillium Chapter
Old Apr 15th, 2003, 12:05 AM
Canada
I use an electric pressure washer on my car
it works fine
just dont put the nozzell too close, that would be stupid.
they are safe for clear coated cars
and no it won't blow the paint off
Cooper Launch Edition # 7/500 Chili red , white roof
Old Apr 26th, 2003, 07:46 AM
wow
Local Time: 12:30 PM
South Africa
Velvet Cooper
I have used a pressure on my velvet red mini with white stripes and I am always impressed afterwards.(Gets brake dust off really well) I wax my car only 5 time a year is that a good idea?
MINI, it is a way of life.
Old May 1st, 2003, 05:53 PM
nobbyclark's Avatar
0.1mpg (Miles per Grin)
United Kingdom View nobbyclark's Electric Blue & White 1st Gen MINI Cooper S Profile
They can strip paint...
...if you have exposed metal at the front or any other part of the vehicle. I also have a LR Disco and the high pressure washer takes great delight in stripping away its 6 year old paint if it gets the chance. So far it hasn't affected the Mini, but that hasn't been perforated yet.
Old May 1st, 2003, 07:02 PM
mark-tifosi's Avatar
finished already
England View mark-tifosi's Solid Black & White 1st Gen MINI Cooper Profile
i prefer to use a pressure washer first and then do a hand wash after, only because i dont like to rub in the grit and dirt that builds up on the paintwork by using a sponge. i just use the pressure washer to remove the top dirt, i wouldnt concentrate the blast to try and remove stubborn dirt, use a sponge for that
as long as you take care i dont see a problem, its clear that they could damage your car if you are reckless with it, but otherwise its fine for me!
Old May 2nd, 2003, 01:25 AM
Oh, you guys are making me cringe.
You shouldn't even use a nozzle on the end of a hose. Slow-flowing water is all you need.
Hey, pressure washers have their uses. They work great for taking mildew from decks before restaining. They work great for taking off old paint from concrete. They work great at removing all the dirt from the cracks and seams in your driveway.
But not on my car.
Dark Silver S
Old May 10th, 2003, 03:33 AM
Polmear's Avatar
Becareful,
Charles
Same thing happened to my 1991 Celica, small chip on the hood, two seconds after the power washer hit the chip, no more clear coat on the hood.
Pressure washers? MaTTy_P Maintenance & MINI Care 59 Sep 13th, 2006 08:58 AM
High Pressure Headlight Washers dc707 General Discussion 11 May 26th, 2005 05:25 PM
Pressure Washers... Good or Bad??? rich Maintenance & MINI Care 8 Jul 26th, 2002 03:59 PM
Pressure Washers - Advice on Buying ricardo Maintenance & MINI Care 9 Jan 25th, 2002 06:11 PM
