Hey guys
So this one has me stumped!!!
A few days ago I got a light on my tachometer for the "engine malfunction" and I lost some power/ my car went into limp mode. few minutes later the car picked up again and all was well! It happened a few more times and the ijit light came on. The code is pointing towards the knock sensor.
Now I called up Detroit Tuned and they said I may have bad gas, I don't think this is the case after doing a few tests, and adding quality fuel.
I have had this problem before a couple months ago, so I changed the spark plugs and the problem was solved.
I plan on draining the tank this weekend up to the cottage, after that I will know if I need to check the knock sensor. Any other points to check?
