Hi guys
I know there's been some discussion on rear washers not working in the past, but none sound like my problem exactly!
When selecting the rear washer, you hear the motor working but no fluid. There's no fluid on the ground and none in the car. The front work OK.....but i'll get to that later.
I removed the rear lining and pulled off the hose to the rear nozzle. Tried to scoosh again, but nothing came out. So it would seem to make sense that no water is getting to the back end. The bottle if proper full under the bonnet.
I read somewhere that it might be the relay. As one does the front and the other the rear. So I swapped them over. No luck. Front still works, back doesn't.
Ata bit of a loss now!!!!
Anyone any ideas?
It's a 2010 Mini Cooper.
Oh forgot to say.......
The front washer is great in short bursts, but if you keep it on for any length of time (more than a 1/2 second) the pressure drops!!!
Could that be related??
Anyone any ideas?
