Which coolant should i use for a R53 06 Cooper S ? - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 3 (permalink) Old Apr 18th, 2017, 08:12 PM Thread Starter
Local Time: 05:23 PM
Quoted: 3 Post(s)
Trying to get my bearings around here so appoligies in advance if i sound like a newb. Just got a 06 Coop S from a relative, and realzied my coolant is bone dry and the engine is overheating. Want to get some coolant in there to see how the car runs before taking it over to a shop.
Was trying to figure out if anything will work or should i be using a specific type?
ANy benefits of using one of these vs another?
  • Pentosin Antifreeze/Coolant-OE
  • BMW
  • PEAK
Thanks guys
06CoopS is offline
post #2 of 3 (permalink) Old Apr 19th, 2017, 12:30 AM
Moderator
minione2002's Avatar
Quoted: 479 Post(s)
Green or blue is recommended.
Pentosin & BMW coolants are good
Make sure she is blend properly and a 50/50 antifreeze mix is used.
Sent from my GT-N7100 using Tapatalk
minione2002 is offline
post #3 of 3 (permalink) Old Apr 20th, 2017, 09:01 AM
Local Time: 03:23 AM
Quoted: 179 Post(s)
Australia Male
Garage
I would just use the BMW coolant as its not expensive, as per minione2002's post, make sure its a 50/50 mix of coolant and deionised or distilled water. Is the car overheating or did you cook it ?, have a sniff of the engine oil to see if it smells burnt and also if its low. be aware of where the bleed screws are and check around the thermostat for leaks.
MINI Cooper Coolant Change (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Milpol is offline
BMW Mini R50, R52, R53 Cooper S Carbon fiber Double Gauge Speedo Meter Ring nvd MINI2 Classifieds 0 Mar 22nd, 2017 09:53 AM
BMW Mini R50, R52, R53 Cooper S Carbon fiber Exterior Side Grilles nvd MINI2 Classifieds 0 Mar 22nd, 2017 09:49 AM
MINI Cooper S vs Fiat 500c Abarth AG Jeff MINI News 9 Jun 21st, 2016 01:47 PM
Help please. Mini Cooper 2004 boiling its coolant JPA-Adventurer First Generation MINI Cooper 4 Oct 19th, 2015 07:09 AM
Cooper s coolant leak - R53 Aaron_burr First Generation Faults & Fixes 3 Oct 22nd, 2012 02:41 PM
