Carccessory.com
Old Aug 16th, 2003, 12:20 AM   #1
olarte
olarte's Avatar
Local Time: 03:08 PM
Question Oil filter? how to change.
Don't know what happened to my post. so excuse the duplicate.
Sorry to sound stupid but...
I got the oil filter from the dealer in the mail.... and it's not what I expected (one encased in metal which screws on).
Does someone have instructions on how to change the filter and the rubber gasket? Or have a link to a writeup?
Ivan
Old Aug 16th, 2003, 02:31 AM   #2 (permalink)
obehave
Mini Mod
obehave's Avatar
Quote: Originally Posted by Slant
1st you'll need to buy a 36mm socket to loosen & tighten the oil filter housing/canister- an adjustable wrench may not have enough clearance under the hood. Then read this:
http://www.minicooperonline.com/modu...pic&topic=5119
All good except the super crack the seal technique. Explanation:
Back the filter cannister off until you feel the O-Ring slip free. You'll know immediately since it will start to turn much easier.
STOP right there. Go any farther and you'll drain oil all over the back of your engine.
Now go do somethiing for 15 minutes. I always let my oil drain at least that long anyway.
Come back, rag in hand. Hold the rag against the back of the filter with your left hand. Spin off the cannister with your right. If you did it right there'll be less than a teaspoon on your rag and ZERO on your car.
Most excellent tip someone came up with here a long time back. I've used it twice with great success.
PS: I've also used this for between oil change filter change so you don't have to drain the oil for this to work.
Old Aug 16th, 2003, 02:36 AM   #3 (permalink)
Slant
Slant's Avatar
Obe, you're slacking... I can't believe I beat you to the post!! And I'm on regular phone line, no DSL or cable!
Old Aug 16th, 2003, 02:46 AM   #4 (permalink)
obehave
Mini Mod
obehave's Avatar
I had actually picked up my guitar and played after not touching it for years.
I now suck Fingers are killing me.
Sounds like a good excuse anyway doesn't it?
Glad you've got power.
Old Aug 16th, 2003, 02:47 AM   #5 (permalink)
paddy
Anyone seen MP lately???
paddy's Avatar
United-States Obe,
I have ordered and waiting impatiently for the Fumoto value. Ordered one with a nipple and one without. I will let you know how it works out.
"We will not tire, we will not falter, and we will not fail..."
-- President George W. Bush - Sept. 20, 2001
United States Male View paddy's British Racing Green & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Aug 19th, 2003, 06:10 PM   #6 (permalink)
Vincent Hill
Mini "S" BRG
I have not seen better advice anywhere! I so not have a 36 mm socket, so I use a 1 7/16" inch socket I had for the VW axle nut! Everything else is the same! You must push the new filter in the cup and push it again to get it in place! I also would prefer a Cartridge filter!
Old Oct 20th, 2003, 07:59 PM   #7 (permalink)
milwaukeeboy
milwaukeeboy's Avatar
Local Time: 02:08 PM
Velvet Cooper
1 7/16 = 36.5 mm. Seems okay to me (couse it must be since the V-dub wasn't SAE either )
Hey I may have something new to add to the procedure.
I did mine without jacking up MINI!
Just slid the drain pan underneath and pulled the plug (I was really glad for the pictures, I had a hard time figuring out which was the sump).
Since you do the filter from the top anyway it was a breeze.
I used the *crack* method to great success. It was a little tough getting the filter housing started again. I was terrified of cross-threading it. Turns out that you need to get it to the O-ring then apply faith and torque in equal measures!
For the record I used Castrol Syntec which I found for $4/qt at a discount auto chain.
-milwaukeeboy
Chili Red/White MCS Born: August 2, 2002
Check Out My Site!
Life is short - Drive Politely!
United States View milwaukeeboy's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 2nd, 2004, 01:50 AM   #8 (permalink)
Windshadow
Windshadow's Avatar
This is the method I have always used with this type of filter... a top notch tip... BUT
This link for the basic instructions seems to be dead... anyone know the updated link?
S BRG/W Randolph 3 PAC NAV
Mid Coast Maine, U.S.A.
United States Male View Windshadow's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 2nd, 2004, 02:21 AM   #9 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 12:08 PM
http://www.northamericanmotoring.com...pic&topic=5119
Old Apr 2nd, 2004, 02:45 AM   #10 (permalink)
Windshadow
Windshadow's Avatar
Cool
Quote: Originally Posted by MINIAC
From your link I found the original which is much nicer to read (Am I the only one that finds white type on black hard to read on a web page?) and print
http://www.webbmotorsports.com/forum...topic.php?t=10
oil and diesel filter change? HElP!!! Kissato MINI One Diesel 6 Feb 19th, 2008 03:58 PM
Oil filter change bemini Maintenance & MINI Care 14 Dec 16th, 2007 04:56 AM
oil filter change garryjohnson Engine & Drivetrain Tuning 4 Jul 19th, 2006 07:57 AM
do i need to change oil filter when changing engine oil? asinn Maintenance & MINI Care 6 Jan 27th, 2005 04:20 PM
oil filter ONLY change Ken2002S Maintenance & MINI Care 2 Oct 6th, 2002 11:15 PM
