Adam's Polishes
Old Sep 15th, 2003, 06:58 PM   #1
alreet
Local Time: 08:45 AM
When should i top my oil up?
Ive had my mini one for 3months now, done about 2,600 miles, and havent even looked under the bonnet yet!, when should i top my oil up? whats the difference between topping oil up, and an 'oil change' thanks
England   Reply With Quote
Old Sep 15th, 2003, 09:24 PM   #2 (permalink)
goin440
Numb from Jäger
goin440's Avatar
Local Time: 03:45 AM
Send a message via Yahoo to goin440
Check the oil level on the dipstick regularly (every other week, every third week... whatever). If its low, top it off. When you turn the key on in the ignition, the odometer flashes the distance to next oil change. For more info, turn to the owner's manual as it is a valuable resource.
Welcome to the "2"
-goin440 IB/IB MC
Old Sep 16th, 2003, 02:34 AM   #3 (permalink)
miniyup
Local Time: 02:45 AM
"Topping up" means just that - checking the level on the dipstick and adding as necessary. Should do this ideally every time you stop for fuel, or at least every other time. Check it after you fill the tank so the oil has time to drain down into the oil pan so you read the level accurately on the dipstick.
"Oil change" means drain ALL the old oil out of the drain plug in the oil pan and, for most people, change the oil filter. If you have never done this before, have someone who is knowledgeable help you do it the first time. The oil filter on the MINI is not like most other cars, check the FAQ/DIY info here for some good tips on how to handle the fllter and oil change in general. You can save a lot of $$ by doing oil changes yourself (vs. dealer's charge) and you will know it's done right (if you know what you are doing). Make sure you use Castrol or Mobil 1 full synthetic motor in the viscosity MINI specifies for your climate.
miniyup
Built 11 Apr & delivered 23 May: 03 MCS EB/W w/ wide stripe F&R, all 3 Pkgs (except wheels - 16" v-spoke), Lapis, Anthracite
United States View miniyup's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Engine Oil ~ Top up billywizz John Cooper Works & GP 1 Apr 26th, 2007 02:42 PM
Cooper S oil- how often do you top up??? minibbb MINI Cooper S 15 Aug 25th, 2006 04:27 AM
Comparison between rag top n tin top road tax?!... why the price difference? hunkey dorey MINI Convertible 7 Aug 31st, 2004 12:57 PM
UK Oil spec - top up StevePSB Maintenance & MINI Care 2 Mar 25th, 2003 09:49 PM
Oil Filter Stuck in Canister Top retroom Maintenance & MINI Care 5 Mar 17th, 2003 12:58 PM
