| MINI2 Jedi Master Join Date: May 2003 Local Time: 05:06 AM
Offline | Magnetic Oil Drain Plug ? I have just been reading about a magnetic oil drain plug which will collect all the metal shavings that come off the engine, mainly during breakin period. Does anybody know if these are worth buying and where you can get them from for the MINI ? Badboyz |
| MINI2 Regular | I think you're just a weee bit paranoid about this. It's not like there are large iron filings floating around your oil. If this was seriously a problem during breakin, wouldn't the service interval be 1,000 miles, then every 12,000 after that? Right. Just calm down and motor on, and everything will be fine. Took delivery on 10/09/2003. Mmmm.... Dark silver. |
| | #6 (permalink) |
| BLIKSEM (my brg/brg mc) Join Date: Mar 2003 Location: york, pennsylvania Local Time: 01:06 AM
Offline | might do a little bit. i always had one on my 82 rabbit, and at every oil change, there was a coating of grey (iron) dust stuck to the magnet. probably a drop in the bucket, though, compared to non-ferrous, silica, dust, dirt, etc. that also find their way suspended into the oil. |
| | #7 (permalink) |
| Mini Mod Join Date: Sep 2002 Local Time: 01:06 AM
Offline | Right or wrong I changed mine at the end of break in. Again at 2500 miles then 5K. Filter only at 7500. There was a good amount of metallic particles in the oil at first change. No analysis done, just looked at it under a microscope. By 5K it was greatly reduced. Excessive? Maybe. My choice? You bet. |
| | #9 (permalink) |
Offline | Yea thanks for the reply's people. I know it sounds pretty paranoid but I don't see what harm changing the oil after about 1500 miles will do and it will almost cost nothing so I might aswell. |
| | #10 (permalink) |
| MINI Traitor | We've been down that road before. I concurr with obehave. That is what you have a filter for. We've had numerous discussions about this before. I suggest doing a search on I concurr with obehave. That is what you have a filter for. We've had numerous discussions about this before. I suggest doing a search on oil sample for a start. I don't think you should go past the thread... anyone waiting 10k?? to start with. Good luck ![]() Clubman less.... ![]() |
| | #12 (permalink) |
| 1st MINI Owner in QLD !!! Join Date: Jun 2002 Location: St George Local Time: 03:06 PM
Offline | Doesn't all Minis and modern cars have that. I know when I changed the oil on my Mini Cooper S it had one fitted. 1968 Mk1 Morris Cooper S 1310cc Downton Lake Green - White 1974 Leyland Mini 1098c Country Cream 2008 MINI Cooper S Chilli Pepper White - Black Roof |
| | #13 (permalink) |
| MINI2 Regular Join Date: May 2003 Location: Michigan Local Time: 01:06 AM
Offline | If you would really like a magnetic drain plug, try this when you change the oil: Take the drain plug, get a 2-3 foot length of insulated wire, wrap the threaded end of the bolt, get some alligator clips, attach the clips to each of the stripped ends of the wire, and hook the other ends of the clips to a small battery; leave for a couple of hours, instant magnetic plug-well not instant, but close. Make sure you dont use a magnetically shielded wire. |
| R56 magnetic oil drain plugs | djam43 | 2nd Gen Engine & Drivetrain Tuning | 0 | Mar 29th, 2007 07:18 PM |
| oil drain plug size | sheaa | Engine & Drivetrain Tuning | 2 | May 12th, 2004 02:02 PM |
| Anyone installed a quick-drain oil plug? | Critical | General Discussion | 0 | Sep 1st, 2003 07:26 PM |
| Has anyone seen or used a magnetic oil drain plug? | Gas O | General Discussion | 5 | Apr 26th, 2003 08:56 AM |
| Oil Drain Plug | Tremoral | Maintenance & MINI Care | 0 | Mar 11th, 2003 02:37 AM |
