Clock-like symbol in the odometer - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 9th, 2004, 12:40 PM
Send a message via MSN to leon1982
Local Time: 05:12 AM
Australia View leon1982's Solid Black & Body Color 1st Gen MINI Cooper Profile
Hi guys...
before I start...I have a Mini Cooper with no satnav option..
okay..here is my question..
I notice there is a clock-like symbol on my odometer next to the figures that show the distance the car has travelled...so it is on the top left hand corner of the odometer...
What does that mean?
Old Feb 9th, 2004, 12:43 PM
swamos's Avatar
MINI Traitor
Send a message via Skype™ to swamos
Australia View swamos's Electric Blue & White 1st Gen MINI Cooper S Profile
Quote: Originally Posted by leon1982
Hi guys...
Ummm... I'm pretty sure that that is the light to indicate your cruise control is active. It's green I think. Should be able to make it toggle with the on off buttons on the steering wheel
Old Feb 9th, 2004, 12:44 PM
warped's Avatar
JCW No. 1459
Local Time: 06:12 AM
Australia View warped's Dark Silver & Black 1st Gen MINI Cooper S Profile
Hi guys...
I got Sat Nav so I'm kind of guessing but would it be your cruise control? Shows up with a green light and sort of looks like a stop watch (speedo)
Old Feb 9th, 2004, 12:50 PM
KenL's Avatar
Local Time: 07:12 PM
Is it not related to the service interval or the brake fluid change?
When you switch on your ignition a number will be displayed which is the miles estimated until a service is required.
While that number is displayed if you press the button to reset the odometer it will display the number of days until your brake fluid needs changed.
I think if the clock is lit up then some sort of service is due.
Old Feb 9th, 2004, 01:16 PM
it's definitely not the cruise control...coz I did not take that option.
about service interval...probably..coz I still have 13800km to go before the next service...
what could it be then?
btw...thanks for the info guys
Old Feb 9th, 2004, 01:21 PM
KenL's Avatar
How old is your car? Brake fluid requires to be changed after two years.
Old Feb 9th, 2004, 01:48 PM
it's 2002..but it's actually dec 2001 built..
doesn't the distance shown on the odometer shows how many k's I still have before the next service? or it only shows the oil status?
Old Feb 9th, 2004, 05:11 PM
KenL's Avatar
When the distance to your next service is being shown press the little but that you use to reset your trip odometer.
That will display a number of days till your brake fluid (NOT oil) needs changing. Think if you have gone past the date it will appear as a - number or flash or something.
Since your car was build Dec 2001 that's more than two years so it's time for a brake fluid change.
Might be worth reading your owner's manual for a wee refresher course
Old Feb 9th, 2004, 06:19 PM
Paul's Avatar
MINI2 No.1
England Male
Abi's has just popped up on her one, so I'm going to read the manual tonight!
Old Feb 9th, 2004, 10:24 PM
DJC's Avatar
DJC
Local Time: 08:12 PM
United Kingdom Male View DJC's Chili Red & White 1st Gen MINI Cooper Profile
Hello, the clock symbol is for the brake fluid change. If you press the trip reset button as you startup, it should display a number with a minus sign in front of it. This is the number of days since the brake fluid should have been changed. I am just about to book in my Jan. 2002 Cooper for its first b/f change. Hope this helps Damian.
Old Feb 10th, 2004, 03:25 AM
IML337's Avatar
saving the world
Singapore Male View IML337's Dark Silver & White 1st Gen MINI Cooper S Profile
That's correct - and it's in the manual
Old Feb 10th, 2004, 07:17 AM
ShermanM's Avatar
Australia View ShermanM's Dark Silver & White 1st Gen MINI Cooper S Profile
Yep, its like a count down timer. Thus, the clock.
ShermanM
Remember to accelerateShermanM
Old Feb 10th, 2004, 08:01 AM
Paul's Avatar
MINI2 No.1
England Male
I was going to reply again after I rtfm but others beat me to it, thanks guys.
Help With Symbol on Dash manutd2k22002 First Generation MINI One 7 Nov 23rd, 2006 02:47 PM
Odometer, clock and trip computer resetting Andu First Generation Faults & Fixes 4 Dec 10th, 2002 05:39 PM
gear linkage fix done -- anyone else's odometer and clock changed? HarryHBMCC First Generation Faults & Fixes 5 Sep 1st, 2002 07:57 AM
