Battery replacement: need to reflash ECU? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 3rd, 2004, 05:36 AM
Local Time: 12:51 PM
There will come a time when the MINI battery needs replacement. When it is disconnected, will this require re-flashing the ECU? I drive the MC and would not want the newer software v.36 update as my car is running just fine. Any thoughts on this?
Old Apr 5th, 2004, 05:07 AM
Wot? Nobody with a replaced battery? Or any expert who has an answer?
Old Apr 5th, 2004, 01:23 PM
Polmear's Avatar
Online
Local Time: 03:51 PM
I left mine disconnected from Nov thru last week, probably the same as changing it out. All I did was wait with the key in pos 2 for a couple of minutes, then start the car. The only thing I had to reset was the clock, even all my radio station presets stayed!
Old Apr 11th, 2004, 04:07 AM
______________-
That's encouraging news. Thanks
Best Battery Replacement? JG.26 Maintenance & MINI Care 3 Jun 16th, 2008 12:22 AM
Battery replacement, Salt water and What is that? MiniG First Generation MINI Tuning 9 Feb 4th, 2007 09:17 PM
Battery Replacement prs First Generation Faults & Fixes 11 Aug 11th, 2006 05:13 PM
Battery Dying / ? Needs Replacement gazah First Generation Faults & Fixes 13 Apr 6th, 2005 05:32 PM
Battery Replacement Tone Maintenance & MINI Care 0 Sep 17th, 2003 02:16 PM
