Jack stands (and ramps for oil changes) - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 13th, 2004, 04:16 AM
Local Time: 10:33 PM
hey guys and gals,
i'm in the middle of trying to change my oil for the first time and i noticed that there isn't room to both jack up the car and slide the stand underneath it. Has anyone done so successfully or am I forced to spend $75 for an oil change? I don't have ramps and the mini looks too low for that anyway. thanks in advance.
Seth
Old May 13th, 2004, 07:54 AM
EBMCS03's Avatar
M5 Extraordinare!
Send a message via ICQ to EBMCS03 Send a message via AIM to EBMCS03 Send a message via MSN to EBMCS03 Send a message via Yahoo to EBMCS03
Local Time: 03:33 PM
United States Male View EBMCS03's Electric Blue & White 1st Gen MINI Cooper S Profile
Ya theres been concern about that. I forgot what people said... but here are some link you can read to find out more info.
http://www.mini2.com/forum/showthrea...ht=jack+points
EB/W MCS Arrived (3/26/03) Premium & Sports Package, Lapis Blue Leather, Harmon Kardon, PDC, Tint, Aux Input, X-Pel Clearbra *SOLD* 4/25/06
Old May 15th, 2004, 05:00 AM
BruceK's Avatar
Moderator & Sponsor
Local Time: 04:33 PM
I've done a number of MINI oil changes with the car virtually sitting on the ground - no need to lift it up. Actually I park the front tires on a pair of 2X4 boards and that 2 inch extra height is all the height I need to slide the oil catch pan under the engine.
Of course the oil filter is accessed from the top of the engine, so other than reaching the drain plug from the front of the car (very easy) and positioning the catch pan, there's no need to raise it up at all.
Old May 15th, 2004, 05:11 AM
obehave's Avatar
Mini Mod
Local Time: 06:33 PM
Rhino Ramps work well. Several folks here have them.
I built a mini ramp out of 4x4. I drive one side up on the curb and the other on my ramp. Works fine.
Old May 15th, 2004, 12:11 PM
CurtP's Avatar
Local Time: 05:33 PM
United States View CurtP's Pepper White & Black 1st Gen MINI Cooper S Profile View CurtP's Classified Ads
2x4's are actually 1.5"x3.5", unless you're using dimensional lumber.
Old May 20th, 2004, 07:09 PM
I thought people life Mini up with their left hand and unscrew the oil plug nut with their right hand. Of course, Americans will do it with our head tilted so we can be talking on cellphone at the same.
Old May 21st, 2004, 04:52 AM
BruceK's Avatar
Moderator & Sponsor
Yes, I know. When I was posting I actually thought about saying 1.5" from the 2X4 is high enough, but I was thinking that would confuse people.
Anyway, I'll repeat that ramps are not needed at all for a simple oil change, in fact a lift of just 1.5 inches works great for me.
Old May 24th, 2004, 01:21 AM
CurtP's Avatar
Well, I was confused, but that's a normal state for me
Thought for a minute that you were pulling a Norm and cutting your own wood planks!
Old May 28th, 2004, 11:28 AM
joeinitaly's Avatar
International Merrymaker
Local Time: 12:33 AM
United States View joeinitaly's Electric Blue & White 1st Gen MINI Cooper S Profile
I went to rotate my tires and jacked up the back to remove the rear tire. I put a jackstand just forward of the jack point and jacked up the front. As the front came up, the rear came off the jackstand, so the entire side of the car was balanced on the little jack. I quickly removed and replaced the front tire and got it off the jack. They really do need to provide jack pads. I do not understand what everyone else was using, an integrated jack/stand unit?
I'd be lost if I had somewhere to be!
Old May 28th, 2004, 05:09 PM
Driven
BruceK is right, you can basically just reach right up under the bumper, and there's the plug. Depending on what you're using to catch the oil, though, it can help to have a little clearance for sliding a pan in & out under there.
In any case, for those of you wondering about ramps, I can assure you the MINI has plenty of clearance for them, if you have ramps with low-rise extensions. I routinely use them with Buzz (the Mini), and have never had a problem.
Photographic proof:
As our driveway slopes slightly away from the garage, it's even better, since we wind up not only with the car nearly level, but a very generous amount of space in front. Makes getting up under the car quite easy.
Of course, if you're on a slope steep enough that it puts the outer leg of the ramps near or past vertical, DO NOT DO THIS. Doing so could be quite bad for the car, and incredibly bad for you. If you don't know why, go back to Basic Physical Science 1.
Otherwise, good luck!
DW
Old May 28th, 2004, 08:42 PM
MiniG's Avatar
Proud MINI2 Sponsor
Great advice for oil changes, what about just lifting the car?
Old May 28th, 2004, 10:54 PM
Lifting the car will increase bicep strength and size, thus improves chances with the ladies.
Old May 30th, 2004, 12:01 AM
Driven
HAHAHAHAHAHAHAHAHA!!!!!!!!
Pretty good, 'thug, pretty good!
DW
Old May 30th, 2004, 12:09 AM
racer-x's Avatar
United States View racer-x's Dark Silver & Black 1st Gen MINI Cooper S Profile View racer-x's MINI Features Album
I Just bought a pair of RHINO ramps today at SEARS, for only $19.95 they worked very well, your also going to need a 36mm socket for the oil filter, and a 13mm wrench for the oil plug. also available from SEARS, I ended up spending a total of $41.10 for all three.
jack stands GTT 280 First Generation MINI Tuning 1 Oct 15th, 2005 04:14 AM
Car Ramps GTT 280 Maintenance & MINI Care 7 Oct 10th, 2005 03:56 AM
Ques re: Jacks and Ramps--Help Please! jmoser Wheels, Tyres & Brakes 6 Sep 10th, 2004 05:54 PM
Floor jack & stands jblow Maintenance & MINI Care 2 Nov 16th, 2003 12:26 PM
Read this BEFORE using Jack Stands sadales Maintenance & MINI Care 12 Feb 3rd, 2003 12:56 AM
