Visit Mini Mania UK
Old May 30th, 2004, 11:08 PM   #1
vpr
Local Time: 06:11 PM
Rear brakes
Hi, was just wondering if anyone has had their rear brakes wear out before the fronts? This has just happened to me. Also it seems that the inside pad wears out quicker than the outside pad on the rear of my car. Does this sound like a brake adjustment problem?
Old May 31st, 2004, 07:17 AM   #2 (permalink)
eltel
MINIstry of Fun
eltel's Avatar
Local Time: 05:11 PM
Yes, happened to me at 40k, metal to metal at the rear, apparently needed new pads and rotors all around as well.
Australia Male View eltel's Liquid Yellow & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 31st, 2004, 08:05 AM   #3 (permalink)
lucky
shiver me timbers
lucky's Avatar
hmmm. . . i had to have new rear calipers rotors and pads at 17k. . . replaced under warranty faulty from factory?
Old Jun 1st, 2004, 02:42 AM   #4 (permalink)
AndrewH
Were there Oompa loompas?
AndrewH's Avatar
Your kidding! How much did all that end up costing you. I was under the impression that pads should last a lot longer than 40k and the rotors should see out a couple of hundred thousand K's (at least that's been my experience on other cars). Oh well, I guess it's like my Dad says, you don’t buy a Rolls Royce and then complain about the cost of petrol.
Old Jun 2nd, 2004, 04:23 PM   #5 (permalink)
mrhollio
road trip time
mrhollio's Avatar
Local Time: 12:11 AM
I just replaced my rear brakes at 14.5K miles. The fronts aren't even half worn. The inside pads were even more worn than the outers. I guess its because of the self-adjusting handbrake cable applys pressures to that side more.
Trust not the heart of a man for whom old clothes, and the Mini, are not venerable!
United States View mrhollio's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 2nd, 2004, 04:30 PM   #6 (permalink)
Jeep-2-mini
World Traveler
Jeep-2-mini's Avatar
Local Time: 07:11 AM
Send a message via MSN to Jeep-2-mini
Had my rears replaced at 14k - blame the greens, the non abestos pads just don't last as long
Lifes a reach ... and then you gybe
Old Jun 3rd, 2004, 08:08 PM   #7 (permalink)
Dave T
Stuck calliper
Mine goes in tomorrow to have the rear brakes sorted. I did not like the looks of the rear disks so I took the wheels off to have a closer look. I found that the N/S inboard pad is worn to "wafer thin" while the outer pad is just about as new thicknesss. It will be changed under warantee, of that I am sure. The disks are still above min thinkness, but the outer part of the swept area is very poor, more so on the O/S. I want new disks too. My Oct 01 Cooper has 18K miles on it.
Tonight the windscreen started leaking again for the 4th time, I have only had the car 7 months
Wales   Reply With Quote
Old Jun 5th, 2004, 09:11 PM   #8 (permalink)
Irlmin
Peoples Republic Of Cork
Irlmin's Avatar
Local Time: 08:11 AM
Send a message via Skype™ to Irlmin
Ireland
45000 miles and NO rear pads yet ,still 50% left ,I just replaced front discs and pads .
Gerard
Ireland Male View Irlmin's Chili Red & Black 2nd Gen MINI Cooper Profile   Reply With Quote
Old Jun 5th, 2004, 09:35 PM   #9 (permalink)
Tonyt3
Track addict
Tonyt3's Avatar
The rears should NEVER wear out before the fronts, this is an impossiblity without some mechanical problem being the cause. If your rears have worn unevenly, it means the calipers have seized, and it should be a warranty job, new pads, new disks (they will also wear unevenly) and new calipers. Happened to me at 25k miles, rears started to make a noise, inside rear pads had worn away completly, damaging the disk. When asked by the dealer how often I had changed the front pads, I pointed out that I had not, and that if the rears were worn then the car was faulty. After scratching their heads a little, they agreed, and replaced the lot inder warranty.
I then pointed out that the car had just been serviced by them 2 weeks before, and asked why they hadn't spotted the uneven wear - wait for this, your not going to believe it - they check the pad wear out without removing the wheels - duh! Seems they measure the caliper gap with the wheels on, thus not seeing uneven wear (the pads only wore out one side). All to save 5 minutes service time. Well, you've got to ask, is this safe practice? After having a service on my car, I would at least expect them to be able to assure me my car was safe to drive.
I wonder, if we were paying for service, rather than TLC, would they take the wheels off and check (thus costing us more in service costs?)
Rear Brakes Lawrothegreat Faults & Fixes 1 Feb 16th, 2007 08:52 PM
Rear Brakes vanos Faults & Fixes 1 Nov 10th, 2006 11:16 AM
Noisy rear brakes - need your help please! Peartreeproductions Wheels, Tyres & Brakes 3 Aug 30th, 2006 07:49 PM
Rear brakes after wash.. Mini Me GB Maintenance & MINI Care 9 Feb 10th, 2005 05:20 PM
Rear brakes changing help required FONTAL Maintenance & MINI Care 1 Oct 29th, 2004 08:27 AM
