FOMSPORT
Old Apr 9th, 2002, 09:09 PM   #1
cathy
Local Time: 04:25 AM
tires and,computers
As a driver of a 31 year old Datsun 240 Z I am quite intimidated by all the electronic gizmos on the new cars. If I remove the run-flat tires with sensors will it affect the computer? I once saw a Vette's computer totally shut down when a tire was changed-car had to be towed to dealer to have a code imputed into the computer.
Old Apr 9th, 2002, 10:15 PM   #2 (permalink)
BruceK
Moderator & Sponsor
BruceK's Avatar
Local Time: 03:25 AM
Re: tires and,computers
Cathy, you have an old Z-car? You must chat with mr.bill who is also a MINI2 member with a Z-car of similar vintage. And, like you, mr.bill is concerned about all the whiz-bang goodies on cars like the MINI.
But back to your original question. Unlike with some cars, Corvettes for example, MINIs don't use radio pressure monitors placed inside each wheel. Instead, on a MINI, the ABS system checks the rotational speed of each wheel as part of its normal functioning to ensure a wheel is not skidding. A side benefit of this is that if one tire looses air pressure it will rotate at a slightly different rate from the other three. By noticing this small difference, the MINI knows of a low air pressure or flat tire situation.
Old Apr 10th, 2002, 07:26 AM   #3 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
Local Time: 10:25 AM
Not according to my dealer
He said that if you fill your tyres with air you have to reset the readings by holding the button for a few seconds under the handbrake. This calibrates the system to the new air pressures in your tyres.
50/50 - who is lying ?
Old Apr 10th, 2002, 08:22 AM   #4 (permalink)
Dom
Test thread infiltrator
Dom's Avatar
Send a message via MSN to Dom
Re: Not according to my dealer
It is still computed using the ABS sensors. By inflating a tyre more, it's size is increasing. The ABS sensors will notice that there's something bigger than it used to be and report it. Calibrating the system to the new settings simply tells it that this is the new correct level.
I expect someone can explain it better than me though!
Dom
England View Dom's British Racing Green & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Apr 10th, 2002, 01:23 PM   #5 (permalink)
BrantV
BrantV's Avatar
Local Time: 01:25 AM
Very nice. So that's how you can run different pressures in front and rear.
Any pics of this reset button?
United States View BrantV's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 13th, 2002, 06:02 AM   #6 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
Surely not
Dom
But my dealer said you did this when stationary. Then how would the ABS be able to detect the circumference of the wheel if it wasn't spinning.
Old Apr 18th, 2002, 12:51 PM   #7 (permalink)
ad087
Local Time: 09:25 AM
I don't know about how it can detect tyre diameter but i do know it goes mad if your tyres becomes over inflated. My two front tyres became a little over pressuered due to heat expansion and as a result set off the tyre warning - this scared the bejezzuss out of me as i was comortable cruising at 3000 revs in 5th on a motorway - when i pulled over and checked my tyre pressures with a digital gauge ( i never trust analogue ones) my front two tyres were at 34psi and my back pair were at 28 - this difference meant the system activated.
Mini One Chilli red with 15 inch pepper pot alloys, ASC+T, alarm, Salt and TLC. If you see me - SL51 MWW - gimme a flash of your lights!!
Scotland   Reply With Quote
Old May 6th, 2002, 05:00 AM   #8 (permalink)
taffster
Hi Guys,
Does this mean that if you've only got the 15" 8 spokes without the run flat tires you still get a tire pressure warning light??
Taff
Wales   Reply With Quote
Old May 6th, 2002, 05:42 AM   #9 (permalink)
Apial
Apial's Avatar
Send a message via MSN to Apial
Calibration is only completed once the vehicle has driven a short distance.
15" 8 spokes with normal tyres still get a pressure warning light, even on the base model. It would be a bit of a disaster to discover you had been driving on a flat with no spare and only the repair kit to fix a tyre that had just destroyed its side wall.
You can drive with any size tyre so far as the pressure alarm is concerned.
United Kingdom Male View Apial's Chili Red & Body Color 1st Gen MINI One Diesel Profile   Reply With Quote
Old May 11th, 2002, 10:07 AM   #10 (permalink)
erazo
erazo's Avatar
Local Time: 02:25 AM
Send a message via Yahoo to erazo Send a message via Skype™ to erazo
Page 62 of the USA owners' manual describes the FTM and illustrates the button. You can download the manual in pdf format from the Owners' Lounge.
United States View erazo's Dark Silver & White 1st Gen MINI Cooper S Profile   Reply With Quote
Computers Birdog Interior & Ice 61 Apr 1st, 2007 09:26 PM
ECU - Computers?? gazkhanuk Interior & Ice 8 May 1st, 2005 09:35 PM
Computers vs. Cars Roscoe76 General Discussion 5 Nov 30th, 2004 03:52 PM
I hate computers.... Paul General Discussion 37 Jun 24th, 2002 05:40 PM
