Visit Derek Woodman MINI
Old Aug 26th, 2004, 10:55 AM   #1
Sushi
Sushi's Avatar
Local Time: 08:40 AM
Send a message via ICQ to Sushi
DIY Changing rear brake pads
Hi, I think there is very little information available about changing the brake pads on the Mini.
I intend to do the rear pads this weekend and I will take pictures and see if I can write a quick how-to guide for everyone.
However, I still have a couple of question before starting the job:
-Should I remove the brake fluid reservoir top before starting?
-Should I need to remove the caliper to set the new pads?
-I know I need a wind back tool for the rear piston, but who knows exactly which adapter fits the best? Any pictures?
-Which other tools are needed? Size of socket?
-Which torque setting for the wheels bolt and caliper bolts?
-Should I lubricate ends of pads, which contact and slide in caliper bracket?
Thanks for any answers
...Sushi
United Kingdom View Sushi's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Aug 26th, 2004, 11:27 AM   #2 (permalink)
Sushi
Sushi's Avatar
Thanks, for the link Max.
So, we have some answers, but still a couple of question.
Let me summarise:
Not really needed (?)
Yes.
Use a socket wrench with a 16mm socket and breaker bar to remove the two bolts that hold the caliper to the hub carrier.
...Sushi
Old Aug 26th, 2004, 01:27 PM   #3 (permalink)
jwardell
jwardell's Avatar
Local Time: 04:40 AM
Send a message via AIM to jwardell Send a message via Skype™ to jwardell
United States Male View jwardell's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 26th, 2004, 02:27 PM   #4 (permalink)
Sushi
Sushi's Avatar
Quote: Originally Posted by jwardell
Yeah I always have a look to the forum before posting anything I actually did post something there, but there is no answer to my questions...
It seems though that Max is the man
...Sushi
Old Aug 27th, 2004, 01:47 PM   #5 (permalink)
Sushi
Sushi's Avatar
Quote: Originally Posted by Max
-Which torque setting for the wheels bolt and calliper bolts?
?????? DUNNO, I do it by feel
-Should I lubricate ends of pads, which contact and slide in calliper bracket?
Not really needed (?) NO, use some copper grease on the spring clips, once fitted to the calliper - being careful not to apply too much.
I found some interesting information on torque settings and lubrication. Car is different but it gives a good idea until someone (me? ) write a good how to for the Mini .
Here are the links:
M Brake Pads
E36 Changing Brake Pads
Calliper bolts are different but I suppose torque could be the same:
Wheel remounting torque is (100NM ~ 73.7 ftlb).
Install the caliper assembly and torque the guide bolts to (30NM~ 22 ftlb~264 inlb)
...Sushi
Old Aug 27th, 2004, 09:33 PM   #6 (permalink)
Sushi
Sushi's Avatar
Regarding the discs on the bottom of one of the page I've put in my links I found that:
Click Me
It still not Mini, but there may be some tips to pickup.
We really need a good source of information about Mini maintenace. Any chance we get a haynes issue at some point
...Sushi
Old Sep 1st, 2004, 04:42 PM   #7 (permalink)
Sushi
Sushi's Avatar
Unhappy
That sucks.
Rear calliper bold is an hex key I don't know which diameter.
BMW didn't have the pad sensors, so I haven't done it yet.
...Sushi
When changing Rear Brake Pads anthony.manders Wheels, Tyres & Brakes 0 Dec 2nd, 2006 04:41 PM
Guide on changing rear brake disks & pads A24MIS Wheels, Tyres & Brakes 2 Aug 31st, 2006 09:59 PM
Changing Cooper S rear brake pads trackdemon Maintenance & MINI Care 1 Jan 10th, 2006 06:23 PM
Changing brake pads on 2003 'S'..Advice needed.. Frank the Tank Maintenance & MINI Care 3 May 17th, 2005 08:08 PM
Tips for Changing Rear Brake Pads Lateralgforce Maintenance & MINI Care 2 Oct 11th, 2004 10:25 AM
