FOMSPORT
Old May 18th, 2002, 11:23 AM   #1
S-Cooper
S-Cooper's Avatar
Local Time: 03:57 AM
Question oil & filter change help with torque settings
Have 300 miles on MCS and like so many of owners plan on changing oil before the 10,000 recommendation. Plan on changing around 2000 for the first change. At this pt. neither the dealer or MINI help line seem to know the torque setting for the oil crankcase drain or the oil filter cap. The oil filter cap takes a 36m socket to remove (from the top). Easy to over tighten. Also hoping someone has changed the oil filter and figured a way to catch the oil from filter from running all over the undercarrage pieces. No clear line straight down to drain. Help from anybody who has changed their oil and filter themselves
reborn Cooper S driver
Old May 20th, 2002, 11:03 AM   #2 (permalink)
space_cadet
Local Time: 08:57 AM
I have done it myself, using a MINI filter.
Drain bolt in sump has a nylon washer built into it,
so it does not have to be very tight. Oil filter cover has an o-ring in it, so that too does not need to be very tight.
I just went by feel, based on how difficult it was to un-do.
Not very scientific, but I am pretty confident that
I have not overtighted anything.
As for oil spillage - I just put a rag around the filter
housing to catch any drips, although the latent oil level
is below the lid, so the only drips you get are from the filter when its extracted. Note that the replacment only fits around one way
You gotta drive it like you stole it!!
Old May 21st, 2002, 04:57 AM   #3 (permalink)
Sealevel
Re: oil & filter change help with torque settings
Originally posted by spectrumm3
...Also hoping someone has changed the oil filter and figured a way to catch the oil from filter from running all over the undercarrage...
Hold a plastic grocery bag around the filter as you remove it and let the filter drop into the bag as it comes off.
Steve
Cooper S: Pure silver/black, Premium, Sport, Black leatherette, 17" R90, 4/19 build, 5/24 delivery.
Oil Filter Torque Wrench MAD Always Maintenance & MINI Care 4 Jul 14th, 2005 11:40 PM
do i need to change oil filter when changing engine oil? asinn Maintenance & MINI Care 6 Jan 27th, 2005 04:20 PM
DIY Oil & Filter Change Jupiter General Discussion 3 Jul 7th, 2004 06:14 PM
Oil filter? how to change. olarte Maintenance & MINI Care 10 Apr 2nd, 2004 02:45 AM
oil & filter change-torque specs. etc. S-Cooper MINI Cooper S 6 Oct 12th, 2002 05:30 PM
