Engine Cleaning - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 31st, 2005, 08:11 PM
Jacko's Avatar
Mortgage Man
Local Time: 07:54 PM
United Kingdom View Jacko's Dark Silver & Black 1st Gen MINI Cooper S Profile
Engine Cleaning
Hi people,
can enyone let me know if they have cleaned their engines yet and if so what bits did they cover up before hosing down?
Jacko
Mid life crisis? - get a Cooper S!!
Old Feb 1st, 2005, 12:47 PM
petecrosby's Avatar
Motorer extraordinaire
Local Time: 03:54 PM
United States View petecrosby's Liquid Yellow & Black 1st Gen MINI Cooper S Profile
Yes and none. I generally just go at it with what's left in the bucket after washing the car and use a long bristle brush. I then just hose it off, crank it, and warm it up so it will dry off.
Old Feb 1st, 2005, 01:03 PM
obehave's Avatar
Mini Mod
Good way to test for bad spark plug wires and connections
I'm a bit careful around the ECU but that's about it. I use flowing water and not a pressure spray. No problems.
Old Feb 5th, 2005, 10:16 PM
Best Personal Regards
Local Time: 09:54 PM
United States Male View pocketrocketowner's British Racing Green & White 1st Gen MINI Cooper S Profile
Moi I use degreaser (Supergreen), let it soak, blast it with high pressure, fire it and let it idle for 15 minutes. THEN i shut it off and manually wipe all surfaces and then use armor all on all the plastic bits.
Old Feb 8th, 2005, 06:00 PM
ScottishMini's Avatar
Local Time: 08:54 PM
Scotland View ScottishMini's Chili Red & White 1st Gen MINI Cooper Profile
Question
I am planning on using degreaser and washing off with a ordinary hose.
Anyone see any probs arising?
Old Feb 9th, 2005, 11:33 AM
Just make sure you fire it afterwrds and let it idle til it dries......if it does not want to start (rare occurrence) then spray WD-40 all over the spark plug wires and inside the distributor cap.
Old Feb 9th, 2005, 11:56 AM
obehave's Avatar
Mini Mod
Too strong a degreaser can be pretty harsh especially on plastics. If you do use it make sure you treat the plastics after. I use 303 Aerospace. There are other less worthy products
Old Feb 9th, 2005, 01:10 PM
andyupnorth's Avatar
Distributor cap? Are you sure?
"Do try to keep up Nigel!"
Old Feb 9th, 2005, 01:26 PM
Polmear's Avatar
Online
yeah, sounds weird, but it works. the oil displaces the water, drying the surface.
BTW: WD-40 really stands for 'W'ater 'D'isplacement formula '40'
Old Feb 9th, 2005, 02:46 PM
petecrosby's Avatar
Yeah, that would make sense except for the fact that the MINI doesn't have a distributor cap. At least neither the MC nor the MCS sold in the US have one. Don't know about the MINI-1 or the MINI-D.
Old Feb 9th, 2005, 03:40 PM
Polmear's Avatar
Online
yea, I didn't even think of the fact that modern electronic ignitions don't need a distributor.
Old Feb 9th, 2005, 06:26 PM
when one washes six engines and three of them have distributors one gives advice in general terms. But I stand corrected I should have said ".....spray WD-40 on any and all ignition related components and their associated connections therewith"
Apologies
You can spray WD-40 or a like product into pretty much anything that comes to mind and it will displace the water. Buy y'all know that....
Now....how does one fix a broken battery charger.....takes juice won't charge,,,,,,
Old Feb 10th, 2005, 07:41 AM
Apologies
I apprecaite all the advice given on this thread, Thanks all.
Also, good to know what the WD stands for, mabe come up in a pub quiz and I shall be a saviour !
Thanks again to all
Old Feb 10th, 2005, 04:16 PM
-----> Just spent an hour looking for the distributor cap
  #15 (permalink)
Old Feb 10th, 2005, 05:18 PM
obehave's Avatar
Mini Mod
It's between the flambus and the snickling.
Can't miss it
Engine and Bay Cleaning Mins21 First Generation MINI Tuning 0 Jun 18th, 2007 03:09 PM
Cleaning the Engine bay lemoncoke Maintenance & MINI Care 24 Aug 16th, 2006 11:50 AM
Engine bay cleaning doombuggy Maintenance & MINI Care 0 Jul 1st, 2005 04:07 PM
Cleaning Cleaning Products... Red Dwarf Maintenance & MINI Care 19 Jun 2nd, 2004 04:18 AM
Cleaning inside the engine bay AussieMini Maintenance & MINI Care 10 Dec 13th, 2002 09:24 PM
