| Running In Hi Stelly. When it comes to running in, there are a lot of different opinions and views. I personally suggest you stick to the running-in information given in the manual that comes with the car. The Manual suggests that for the first 1,250 Miles or 2,000 KM you should drive at varying engine speeds, without exceeding 4500 RPM or 150KM/h. They also say that you should absolutely avoid putting the accelerator in full-throttle or kickdown position. After the 1250 Miles/2000KMs engine speeds can gradually be increased. You should also take brakes and the clutch into cosideration. No heavy braking should be done under 300Miles/500KM. Even then, you should try go easy on them for a while. The clutch needs 300 Miles/500KM as well. I am sure you will get many different opinions though. All the best. SuperCharged |
| Some people like to change the oil after the "break-in" period as they believe the filter will not catch any microscopic particles of metal that might have been liberated when the engine wears in. For years it was standard practice for cars to have this early oil change. Manufactures of vehicles and producers of synthetic oils say this is no longer necessary due to advances in technology. At the end of the day it is your choice if you do it or not and no one has been able to come up with a definitive argument for or against. Oil tests on break-in oil done by members of the forum have been inconclusive but the general condition of the oil has suggested that it makes no difference one way or the other whether you change it after break-in or let it go to 10k miles. Basically, I'm sitting firmly on the fence as it's a contentious subject! Someone will be along shortly to put an argument firmly in favour of doing an early change. "Do try to keep up Nigel!" |
| Me, me, me! Oh, I just can't be bothered to go through all that again It doesn't really matter though, because whatever I say will be contradicted by someone who feels it is right to negate all the benefits of greatly improved oil technology by leaving that wonder oil in place until it's completely knackered!Tigger. PS Enjoy your new MINI, they're great. ![]() May '04 - Feb '07 R50, Feb '07 - May '10 R53. Enjoyed our time with MINI's, but ran out of space! Now Focus RS & Land Rover powered... |
| Just my two pence worth... 1. I followed the manual's guidance for the run-in, except the odd foot flat on the floor to about 4500rpm, and later on (after about 850miles) the rare foot flat on the floor until 6000rpm. My reasoning being that the valves will benefit from the very occasional experience of being fully open. You aren't gonna break it, you definately shouldn't do it too often (until after 1250miles ), but I genuinely believe it's gonna give those valves a proper run-in period.2. See above. 3. Nope can't help here..... As a further bit of info, I've used Shell Optimax almost exclusively since day 1, and it is definately better than normal 95RON for engine responsiveness, and far more lively in the screamin' banshee 4500rpm to 6000rpm Looked at the oil the other day, for a top-up, after almost 9000miles and it looked almost new Can therefore highly recommend the magical nectar that is Optimax. And no I don't work for 'em |
| I don't know if you could, but I certainly wouldn't recommend that you did. This is because you will then loose one "free" service and gain a "free" oil change. You would, therefore, be a lot worse off financially. Tigger. ![]() May '04 - Feb '07 R50, Feb '07 - May '10 R53. Enjoyed our time with MINI's, but ran out of space! Now Focus RS & Land Rover powered... |
| Although this thread is a little dated, it applies to me...... What is the thinking 'now' with regards to early oil/oil filter change, is there some conclusion, recommendation? I have just hit 2,000km in my Cooper S works (factory fitted) Oct 2005 build. I have been told that as it is factory fitted a 2,000km oil change is not required (normally the case for non-factory fitted I believe). I have not driven the car hard at all. Also, stupid question but what is this TLC 'thang' ....I am guessing it does not exist here in Switzerland.. Thanks! |
| Interesting engine running in article (running in = breaking in) | R1 | General Discussion | 61 | Oct 5th, 2009 08:18 PM |
| MINI Running Out Of Ones | Hat | General Discussion | 24 | Oct 28th, 2006 12:26 PM |
| Running in a New Mini ? | pdt1066 | First Generation MINI Cooper | 13 | Jun 28th, 2006 09:38 PM |
| Running in your Mini | Badmao1 | Maintenance & MINI Care | 16 | Apr 20th, 2004 01:26 PM |
| Running in new Mini | shelts | General Discussion | 6 | Mar 1st, 2003 03:08 PM |
