Rear brakes after wash.. - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 3rd, 2005, 03:27 PM
Mini Me GB's Avatar
Local Time: 07:55 PM
United Kingdom Male View Mini Me GB's Thunder Blue & Silver 1st Gen MINI Cooper S JCW GP Profile
Question Rear brakes after wash..
Everytime after I give my Mini a wash, the next morning I try to reverse out the garage and the rear brakes seem to stick for a second.
The first time I couldn't move and thought the handbrake was still on, checked but nope and then a second later the brakes released.. Today they stuck again before making a bang sound and letting me go.
Is this just where the water has settled over-night or something else? I've checked and it doesn't seem to happen after the initial reverse.. Afterwards I did a bit of heavy braking to try and make sure all the water was out..
thanks for any help!
Old Feb 3rd, 2005, 03:40 PM
rhardaker's Avatar
Big Grin...
Send a message via MSN to rhardaker
Local Time: 08:55 PM
United Kingdom Male View rhardaker's Classified Ads
yep, always happens - it's just the pads sticking to the discs due to rust build up from washing. Best thing is to have a short drive after washing and if possible (like if you're parking in a garage) leave the handbrake off but the car in gear!
IBMiniG's Avatar
Local Time: 12:55 PM
I have noticed this too, but I'd say the sound I get is more of a chirp. Only happens when the car is left overnight after a wash. I wash in the driveway and pull forward about 10 feet into my garage.
Never gotten stuck and no big noise so I just ignore it now.....
WARNING-Objects in rear view mirror have a tendency to disappear!
9/20 build '03 MCS IB/W/W, everything but the NAV & Sunroof
Old Feb 8th, 2005, 05:44 PM
ScottishMini's Avatar
Scotland View ScottishMini's Chili Red & White 1st Gen MINI Cooper Profile
Scotland
I have had this problem mildly since getting the car. However, after washing the car a couple of weeks ago, it didn't move for about a week.
THEN, when I did go for a drive, it stuck on as usual, so I thought just to go a little further forward. After about 3 metres it was still on. (its OK it was chips, not tarmac or concrete)
I then reversed a little and clunk, it released. Mind you, I then had to rake the chips on the driveway when I got home, as there was a TRENCH 3 metres long and 10cm deep !!!
I would agree with other comments on here about driving a bit after a wash and DEFINATLY leaving the handbrake off.
Old Feb 9th, 2005, 10:14 AM
Quote: Originally Posted by Max
...to add....>
Yr stock brake pads are made of steel compound, the rear discs are steel.
when they both get wet and you apply the handbrake, rust forms and holds the pads to the discs (rotors) overnight.
Max
I was thinking on changing to the likes of EBC discs and greenstuff pads, would this make a difference?
Old Feb 9th, 2005, 01:30 PM
Polmear's Avatar
Online
Local Time: 03:55 PM
depends on the compounds they use. I believe that one of the main ingredients in most NAO (non-asbestos, organic) pads is steel wool. If this is the case with greenstuffs, nope...no difference whatsoever.
Old Feb 10th, 2005, 07:44 AM
Anyone recommend another pad ?
Old Feb 10th, 2005, 12:30 PM
Polmear's Avatar
Online
I think you'd have to go to a high-temp, ceramic race pad to avoid this problem completely, however those pads bring up their own issues; like needing to be heated well before they really begin to perform well, excessive wear on the rotor, noise, noise, NOISE (sorry, didn't mean to shout)
All brake pads are a compromise in one way or another.
The easiest way to avoid this is to drive around after washing and heat up the brakes with a few stops, before putting the car away for the night.
GL and happy motoring!
Old Feb 10th, 2005, 03:54 PM
Thanks for the comment Polmear.
I guess that Ceramic ones are a tad noisy!
Old Feb 10th, 2005, 05:20 PM
Polmear's Avatar
Online
they'll tend to be noisier until they heat up. you'll probably hear lots of low-pressure squealing while cold. I also tend to be extremely finicky when it comes to brake noise...one of many problems when you deal with brakes on a daily basis, and see how much effort is employed to minimize NVH from brakes, we have an entire department devoted to nothing but.
Removing Rear Wash Wipe Question. Merlin 2 First Generation MINI Exterior 10 Jun 7th, 2008 11:16 PM
Rear Wash The Black Pearl First Generation MINI Exterior 3 Mar 6th, 2007 09:22 PM
Works GP rear wash wipe.... Tonyt3 First Generation Works 25 Oct 2nd, 2006 08:07 AM
they changed the rear wash Hat General Discussion 14 Dec 9th, 2004 06:19 PM
Rear Wash/Wipe Problem AntH First Generation Faults & Fixes 1 Apr 9th, 2003 12:29 AM
