| MINI2 Master | Is the clutch on the 5-speed Cooper hydraulic or cable? The parts list posted on another thread lists hydraulic clutch cylinders so I imagine it is hydraulic. If so, is it a system that might need to be flushed or topped off at some point or is it maintenance free? I've only owned cable clutched vehicles before but don't see any clutch fluid resevoirs either in the owner's manual or in under the hood so I'm wondering if it really is hydraulic? Harry MINI Cooper Cabrio: now the car with go cart handling really feels like an open go cart! "... the only man that can come home at 3 am in the morning without getting into trouble with his spouse is the owner of a British sports car!" -- Phil Bailey |
| MINI2 Master | 20 views and no one has a clue? Guess I'll post in general... MINI Cooper Cabrio: now the car with go cart handling really feels like an open go cart! "... the only man that can come home at 3 am in the morning without getting into trouble with his spouse is the owner of a British sports car!" -- Phil Bailey |
| Spectator Join Date: Feb 2002 Location: Raleigh, NC Local Time: 08:32 AM
Offline | The VW Jetta GLX I used to have had a hydraulic clutch that tapped into the brake fluid reservoir. One of the tasks when changing the brake fluid was depressing the clutch pedal several times in order to flush the old fluid out of the clutch slave cylinder. Chip H. ex-MINI Cooper S owner and all around good-guy |
| MINI2 Regular Join Date: Dec 2001 Location: Philadelphia,PA Local Time: 07:32 AM
Offline | The clutch is hydraulic.You can top off as needed,but every two years you should flush the brake and clutch systems and refill with fresh fluid.The MINI uses Castrol fluids,so that means(I think it means)the hydraulic fluid is Castrol Response DOT 4.Castrol Response DOT 4 and Super DOT 4 are not sold in the US,but you can use any quality brand DOT 4 fluid in the car. |
| MINI2 Regular Join Date: Oct 2001 Location: Texas Local Time: 06:32 AM
Offline | Brake fluid I'd guess Castrol LMA fluid would be acceptable. Personally, I use ATE Super Blue fluid in my vehicles, and alternate it with ATE's amber colored version of the same fluid when performing a flush - the color change lets you know when all the old fluid is gone! |
| Will a Cooper S clutch fit on a 2003 Cooper? | flatland69 | Engine & Drivetrain Tuning | 2 | Sep 6th, 2007 06:17 AM |
| Cooper S clutch rattle? | Barry Spooner | General Discussion | 2 | Jul 25th, 2007 03:53 PM |
| Cooper S clutch problems | Mini-Medic | MINI Cooper S | 6 | Jun 29th, 2006 09:54 AM |
| Clutch fluid? | Zipperblues | Maintenance & MINI Care | 4 | May 21st, 2006 11:35 PM |
| Brake Fluid change. How's this affect the clutch? | obehave | Maintenance & MINI Care | 4 | Dec 31st, 2003 05:00 PM |
