| What's this red line for? Join Date: Nov 2004 Location: Atlanta Local Time: 10:49 PM
Offline | This website proved helpful for info on DIY oil changes here It's from 2003. I know there have been some changes over the past couple of years. Would it still be accurate for 05 models including cabrios? Thanks |
| Obsessive Not Compulsive Join Date: May 2004 Location: Edmonton, Alberta Local Time: 09:49 PM
Offline | Just completed my first MINI DIY oil change today on my '04 Cooper. Pretty straightforward really, did not make a mess either. Fitting the filter canister back in place is a little tricky as you must overcome the spring tension before starting the threads - but it just takes a little trial and error to ensure it is square to the block. The only oops! I had was in attempting to dip the O-ring gasket into the fresh Mobil 1 I dropped it into the 4 litre container! Needless to say the gasket got well lubricated. ![]() |
| DrJ Join Date: Mar 2004 Location: Staffordshire, UK Local Time: 04:49 AM
Offline | I was about to do my first DIY change but then discovered Lohen will do it for £40 plus oil and filter cost so I've taken the lazy route and it's going in next month ![]() [ MCS Works, Eibachs, EBC Greenstuff Discs and Pads, Whalen Shift Machine, Toyo Proxes T1-R's Hold on Tight |
| Oil Pressure Light After Oil Change | tpwmini | Engine & Drivetrain Tuning | 6 | Apr 20th, 2005 02:50 PM |
| Oil Pressure Light after Oil Change | tpwmini | Faults & Fixes | 0 | Apr 16th, 2005 03:46 PM |
| do i need to change oil filter when changing engine oil? | asinn | Maintenance & MINI Care | 6 | Jan 27th, 2005 04:20 PM |
| oil cooler-Does it drain when when having oil change? | yorobby | MINI Cooper S | 4 | Sep 29th, 2004 12:00 AM |
| First oil change> Do I have to drain oil cooler ? | yorobby | Maintenance & MINI Care | 3 | Sep 26th, 2002 07:44 PM |
