Visit Derek Woodman MINI
Old Mar 16th, 2005, 02:46 AM   #1
SupeRub
Becoming Stealthy
Local Time: 05:13 AM
Rear Brake Pad Wear
Hi all,
Just got my cooper back for new brake fluid and new brake pads & was told the only the rears needed to be replaced and that the fronts were fine.
I have done nearly 44k km and was sure that if anything the front would need to be replaced and not the back.
Is this a common occurrence?
the service adviser said that it might be caused by leaving the park brake on, however I don't think that is the case.
any ideas?
Ruben
Old Mar 16th, 2005, 03:26 AM   #2 (permalink)
ScottyB
Take me down to Paradise
ScottyB's Avatar
Local Time: 06:13 AM
Im pretty sure that under heavy braking (or perhaps any braking), the rear brakes activate first.
Al (GOGADGET) has his rears replaced first too.
From what Ive read, I understand it to be pretty common.
- Global Moderator - MY BLOG - Global Procrastinator -
... Buying the 8C for its dynamic abilities is like buying a porn film for its plot ...
Australia Visit my Blog at the Motorcade Male View ScottyB's Pure Silver & Black 1st Gen MINI Cooper S Profile View ScottyB's MINI Profile Images   Reply With Quote
Old Mar 16th, 2005, 03:31 AM   #3 (permalink)
ScottyB
ScottyB's Avatar
Heres some threads that may help you too Ruben:
Brakes Pads worn more on the rear?????
and
Rear brakes
Cheers,
Scotty
Old Mar 16th, 2005, 08:29 AM   #4 (permalink)
SupeRub
Becoming Stealthy
Cheers Scotty,
I had a quick search but it didn't turn up anything.
Thanks for the links
Rub
Old Mar 17th, 2005, 02:30 AM   #5 (permalink)
BWROOFCHEX
drive it like i stole it
BWROOFCHEX's Avatar
Local Time: 03:13 PM
you may want to check if your rear calipers are hanging up a little..i replaced my rear calipers myself, because the dealer couldn't see the problem. however, when i released my e-brake, the levers on the rear calipers would intermittently hang up..i noticed this one day on a slight incline, i released the brake and the vehicle wouldn't roll. I jacked the car up and the rear wheels wouldn't spin with ease. I physically tapped the e-brake levers on the calipers and they released.....they didn't stay on enough to cause smoke or any symptoms with exception of premature brake wear. after i replaced my calipers, i haven't had a problem since.
Old Mar 22nd, 2005, 09:46 PM   #6 (permalink)
Boy -with_the_toy
Local Time: 08:13 PM
front brake pads and discs!!
hi does anyone have any idea whether the front discs, pads and calipers off a mini cooper S would fit on a mini cooper??
are they the same discs and pads??
Brake Pad Wear Warning Light Problems goldminicooper Wheels, Tyres & Brakes 2 Sep 9th, 2007 03:23 PM
brake pad wear indicator Alfie General Discussion 2 Sep 13th, 2006 10:05 PM
disabling the brake pad wear sensor light on the dash? scooperman_uk Maintenance & MINI Care 2 Aug 14th, 2006 01:15 PM
Brake Pad wear light come on when worn? Rayman Wheels, Tyres & Brakes 1 May 1st, 2006 07:17 PM
rear brake pad question cruise_carter Wheels, Tyres & Brakes 19 Dec 4th, 2005 04:36 PM
