| Yes it may turn out to be a bit pricey to run in the summer but in the winter will you use a chamois and get frostbite on your hands or buy another filter . ![]() Some people are like a Slinky ........ not really good for anything, but you still can't help but smile when you shove them down the stairs |
I saw it mentioned in the Sunday Times the other day.I would buy only if I could use my Zymol products through it as the drying function and spotless water are two great features.However,those functions will not be put to use unless one uses the Flash cleaning stuff,I believe. |
| "Officially" you should only use flash shampoo but as long as the shampoo isn't really thick I can't see a problem with using other makes.. The flash liquid and autoglym look to be pretty much the same thickness. After my first use i'd say it's excellent and surpassed my expectations. No water marks - probebly the best cleaning job i've done and in an hours less time than normal! |
| The shampoo is just like the Meguiars Next generation shampoo, its got special polymers in the shampoo that make the water sheet off. The problem with my washing is the amount of chalk in my water that stains my car if it drys on it. The filtered water will work perfectly with my Meguiars shampoo. I really want one! Not going to bother at all with the refills of the shampoo. I'll use my good meguiars stuff! |
| Anyone even remotely considering this......you HAVE to get one!! I used it today and am shocked to say it does exactly waht it says on the tin (box!) ![]() Washed the car, rinsed etc (as per instructions) and walked away. Car was still covered in tons of (beaded) water....i wrongly assumed all the water would sheet off....but panic not! 15/20 minutes later the water had mostly evaporated and left behind not one single spot, fantastic! ![]() Buy one, you'll not regret it. |
| My friend was actually demonstrating these at the Excel Autoshow about 6 weeks ago. He had to do it non-stop, 6hrs a day, for about 1 month. Involved spraying a "dirt" solution at the car, and then washing it off. Apparently, washing a (saloon) car takes 10-15 minutes, tops. MINI should be more like 8-10mins. He says it is worth getting, and I for one believe him as he has had the most practice of almost anyone!!!! Havent tried it myself, though. |
| Vaccum cleaner for the car | techiedoc | Maintenance & MINI Care | 3 | Aug 2nd, 2004 07:52 PM |
| Cleaner | the nuke | Wheels, Tyres & Brakes | 2 | May 17th, 2003 01:28 AM |
