| Mini Tragic Join Date: Jan 2005 Location: Menai, Sydney Local Time: 06:42 PM
Offline | Oil Filter Torque Wrench Does anyone use a Torque Wrench to tighten the recommended 25nM when they replace the oil filter. |
| Mini Mod Join Date: Sep 2002 Local Time: 04:42 AM
Offline | Yes but that's in reference to a totally different design. And hand tight only is usually incorrect as well. Most are tighten to contact plus 3/4 of a turn. If you measure that it's right around 12lbs/ft. The canister type filter that the MINI uses is like the ones that I used to use on trucks back in the '70's. They were stronger. That's back when hitting 80-90psi oil pressure wasn't that unusual. At that pressure your cheap spin ons would balloon like Homer Simpson. If I remember right they were torqued to 18-20lbs/ft. 25Nm is 18.44lbs/ft. Last edited by obehave : Jul 14th, 2005 at 02:12 AM. |
| MINI2 Newbie Join Date: Nov 2003 Local Time: 03:42 AM
Offline | I tighten mine with a torque wrench, but then I'm pretty particular about my Mini. I doubt many people torque the filter and/or the drain plug to spec (including dealerships) but If you've got the wrench and the sockets, why not? Maybe it's just me but I feel a certain sense of satisfaction by doing so. |
Offline | I will try to use a Torque Wrench when the time comes for me to do my first oil change. I use them at work (in the aircraft industry) and I much prefer to use Torque Wrench if you have the required torque setting, specified. Someone has gone to the trouble to work out the optimum torque setting, the least I could to is use this knowledge. |
| Reputable & affordable place to get my oil/oil filter changed | spmprnl | MINI Cooper S | 1 | Feb 12th, 2007 03:39 PM |
| Using a torque wrench... | Pinball | Wheels, Tyres & Brakes | 3 | Mar 7th, 2006 09:39 AM |
| AccuTorq vs Torque Wrench | paco | Wheels, Tyres & Brakes | 9 | May 13th, 2004 12:53 AM |
| oil & filter change-torque specs. etc. | S-Cooper | MINI Cooper S | 6 | Oct 12th, 2002 05:30 PM |
| oil & filter change help with torque settings | S-Cooper | Maintenance & MINI Care | 2 | May 21st, 2002 04:57 AM |
